May 19, 2012, 08:51:11 AM
Dirty Tj
Topic: Dirty Tj (Read 1629 times)
Lumbuse
Re: Dirty Tj
Reply #30 on:
February 28, 2011, 09:33:48 AM »
I pulled out the factory radio yesterday and the locking bar. I will need to make a panel to close up the hole as it is too big but I think it will fit ok. Looks like it will stick out about 1/2-3/4". I have some 1/8 " aluminum sheet to make the face plate and new mounting bracket out of. I should get the arb switches from Ian while I have it apart and install them too.
Re: Dirty Tj
Reply #31 on:
February 28, 2011, 11:38:13 AM »
Quote from: Lumbuse on February 28, 2011, 09:33:48 AM
the switches are right next to the axles
Lumbuse
Re: Dirty Tj
Reply #32 on:
February 28, 2011, 11:52:55 AM »
I knew there around somewhere, what's the axle tube welding schedule? Do I need to get some rod for that?
Re: Dirty Tj
Reply #33 on:
February 28, 2011, 12:04:14 PM »
Quote from: Lumbuse on February 28, 2011, 11:52:55 AM
rod is in the mail
Lumbuse
Re: Dirty Tj
Reply #34 on:
February 28, 2011, 12:07:26 PM »
He said mail rod.... he he haha
Re: Dirty Tj
Reply #35 on:
February 28, 2011, 03:11:46 PM »
i've really been enjoying arc welding lately so i thought i'd weld them up. the rods will probably arrive at the end of the week.
Lumbuse
Re: Dirty Tj
Reply #36 on:
February 28, 2011, 03:13:57 PM »
Cool let me know and ill be there if I can.
Lumbuse
Re: Dirty Tj
Reply #37 on:
March 01, 2011, 01:07:09 PM »
Picked up a new tranmission oil pan, filter and magnet today that should cure my leak. I still need a new bushing for the trans mount, and i'd like to put in a trans cooler too.
Lumbuse
Re: Dirty Tj
Reply #38 on:
September 04, 2011, 01:46:59 AM »
Wow I guess it has been a while.
Well the rear axle is in, along with a new adjustable track bar ( JKS with jonny joint ). Need to work on the rear brake lines and find a steel sleeve that goes inside the Rubicon Express bushing. I have 3 out of 4 front control arms in. I'll install the front track bar and tie rod / drag link in the morning. Will also need to set the rear pinion angle.
Dirty Tj
