February 22, 2018, 09:04:53 PM
Author Topic: Family buggy build  (Read 8542 times)
Offline Steve-O
Family buggy build
« on: August 29, 2015, 07:49:17 AM »
Picked up my friends unfinished project, it has some top notch fab work and some major bling stuff
120 wall 1.75 Dom
60 front spooled 35spline chromo outers sterling 10.25 rear welded both with 5.13s
Psc full hydro, wristed radius arm front, leaf rear, 22r on pane with a doubler
Air bumps,
Going to modify it to a 4 seater and build s dependable family rig I don't have to worry about
Update
Current specs
Toyota 22r with got propane kit
Toyota R151f turbo trans
Toyota 23 spline doubler with 4.7 gears in the rear case
Marlin crawler 30spline Chomoly tcase output
Dana 60 front and sterling 10.25 rear
5.13 gears spooled front welded rear
ECGS drive flanges
35spline Yukon outers stock inners
114in wheelbase
PSC full hydro with a single ended ram and forklift steering colum modified for a quick connect wheel
Wristed radius arm front with 1.25 hiems on xj coils
Ford f250 leafs in the rear
H2 wheels with inner air locks and aluminum stiffeners
Air bumps in the front
14in fox nitrogen shocks front and rear
Plans
Swap the rear leafs for a double triangulated 4 link with 1.25 ends
Possibly convert the radius arms to a conventional 3 link
1410 yoke fir the 60 to match the sterling
New suspension seats for the front bench for the back to replace the haggard ones in it
Rear driveline disconnect
Sway-away 2.5s for the rear
I'll add to this post and modify it as I go
« Last Edit: September 16, 2015, 08:18:07 AM by Steve-O »
new england toyotaz?
Re: Family buggy build
« Reply #1 on: August 29, 2015, 09:00:20 AM »
very nice....looks like a good platform to start from.
« Reply #2 on: August 29, 2015, 05:32:14 PM »
what is your plans for the motor?
Offline Steve-O
« Reply #3 on: August 29, 2015, 05:39:03 PM »
Going to use my 3rz
« Reply #4 on: August 29, 2015, 05:42:52 PM »
your going to canabalize your yota?
how long do your think your build will take?
Offline Steve-O
« Reply #5 on: August 29, 2015, 10:01:12 PM »
Yes the yota will be stripped, as far as a timeline I'm not going to set one I don't want to skimp on it at all and take my time building it
« Last Edit: August 30, 2015, 12:07:46 AM by Steve-O »
« Reply #6 on: August 30, 2015, 07:45:42 AM »
nice!
Offline Steve-O
« Reply #7 on: September 16, 2015, 08:29:02 AM »
Updated the first post
Picked up some major toyota bling
R151f with a 23 spline doubler set up.  4.7 gears in the rear case and a marlin 30 spline output kit on the rear output
I want to put a 30spline front output on it eventually but marlin has been sold out for months
« Reply #8 on: September 16, 2015, 08:32:02 PM »
I hope you get it put away and out of your driveway.  It would be horrible if it should go missing overnight.   :smiley_puke_ani:
Offline Steve-O
« Reply #9 on: September 16, 2015, 08:34:07 PM »
It's locked up in the garage
Offline Steve-O
« Reply #10 on: October 04, 2015, 10:04:33 AM »
Not a very big update but I got all the emissions stuff I don't need stripped off the motor made my egr delete plates and got the r151f installed
« Reply #11 on: October 04, 2015, 10:26:28 AM »
Nice work.  I like seeing an engine with minimal stuff on top.  8)
« Reply #12 on: October 05, 2015, 01:10:03 PM »
Keep it up, love watching
Offline Steve-O
« Reply #13 on: January 17, 2016, 09:15:20 PM »
Got a little work done toda got the rear axle out and stripped of all the leaf spring brackets, and made my truss for my uppers
Offline Steve-O
« Reply #14 on: February 02, 2016, 09:31:48 PM »
Got some cage work done over the weekend with some help from Tim and Larry
Got my rear uppers in
Not to crazy on this part might redo it
« Last Edit: February 02, 2016, 09:40:33 PM by Steve-O »
