February 22, 2018, 09:22:22 PM
Author Topic: My 8  (Read 4126 times)
Offline Bosox
Re: My 8
« Reply #75 on: September 30, 2017, 08:57:55 PM »
That door panel is fancier than anything on my rig...
Nice work!
Stickies are plenty fancy...
SI VIS PACEM PARA BELLUM
Re: My 8
« Reply #76 on: October 01, 2017, 07:04:56 AM »
If you use a tube clamp and put it above the basket on the c pillar where it is at an angle, assuming your front mounts are solid, it would very sturdy, the mounts won't move and not impede any storage below.
Offline Bosox
Re: My 8
« Reply #77 on: October 01, 2017, 08:33:24 AM »
That's the plan, just need to figure out the front mounts
Re: My 8
« Reply #78 on: October 01, 2017, 11:02:39 AM »
Yeah, they are.  I woudnít know... :(
Offline Bosox
Re: My 8
« Reply #79 on: October 01, 2017, 01:00:19 PM »
Oops, thought they were...
Offline Bosox
Re: My 8
« Reply #80 on: October 08, 2017, 06:01:46 PM »
Rivets are def cooler than tek screws
Re: My 8
« Reply #81 on: October 11, 2017, 04:50:18 AM »
i love a good dimple die
Offline Bosox
Re: My 8
« Reply #82 on: December 02, 2017, 09:33:04 AM »
Started getting my grill and hood ready for paint
Apparently reproduction parts arenít of the highest quality...lots of divots to fill
Primed and ready
The hood needed a little mud too...
Offline Bosox
Re: My 8
« Reply #83 on: December 06, 2017, 02:24:12 PM »
https://www.ebay.com/itm/1999-2006-DBC-Vortec-4-8-5-3-6-0-Standalone-Harness-with-4L60e-Transmission-/18266395200
The cut down harness currently in my CJ is kinda a mess. Last trip to F&F I was having problems with the fuel pump relay. With Cormierís help we finally got it to stay running the rest of the day but a more permanent fix is needed. Iím thinking a stand alone harness might speed up the process a bunch and looks nice and tidy too...
Anybody go that route on their rigs?
« Last Edit: December 06, 2017, 02:27:29 PM by Bosox »
Re: My 8
« Reply #84 on: December 06, 2017, 04:37:42 PM »
Is your current harness a pinned out factory harness?
If so, does it use the stock gm underhood distribution center? If so, I wager the issue is not the harness but in the distribution center, the internal solder connections on older unit have been for letting go. I want to say pre - 05. Easy fix is to split the box and fix
Offline Bosox
Re: My 8
« Reply #85 on: December 08, 2017, 12:46:47 PM »
Yes, itís a stock harness. There was a ground issue coming out of the pcm as well has some less than stellar connections at the relay/fuse block...I was thinking that a new standalone harness would remedy those as well as clean up the wiring mess a bit. Itís pricey though!
Offline Bosox
Re: My 8
« Reply #86 on: December 14, 2017, 08:35:20 PM »
Big Griffin LS swap radiator with Derale fans. I might have polished it...
Re: My 8
« Reply #87 on: December 15, 2017, 07:29:35 AM »
Must have been a good year for outboard re-powers... :rockon:
Re: My 8
« Reply #88 on: December 15, 2017, 10:44:26 AM »
sweet!
Offline Bosox
Re: My 8
« Reply #89 on: December 15, 2017, 02:23:02 PM »
Haha. Actually I found it on eBay for a screaming deal ($100), Itís a couple years old but never had coolant in it. The Derale fans are pretty reasonable too...
Gotta save my pennies for a garage!
ExtremeTerrain Ė Jeep Wrangler Parts
