May 25, 2012, 01:13:23 AM
My buggy build
4
5
6
7
8
44
Topic: My buggy build (Read 22059 times)
Re: New to me buggy build
Reply #60 on:
January 16, 2010, 10:58:43 PM »
Quote from: Axle on January 16, 2010, 02:24:13 PM
what are the wheels?
KMC beadlock wheels
Reply #61 on:
January 18, 2010, 09:26:40 AM »
sexy!
webmaster@newenglandjeepz.org
Reply #62 on:
January 18, 2010, 11:48:13 AM »
I love those wheels.. They remind me of the Isuzu ones from teh mid 90's for some reason
cj7fan
Reply #63 on:
January 18, 2010, 12:11:00 PM »
what are you running for a compression ratio for the motor with this work?
Quote from: mika401 on January 15, 2010, 10:49:12 PM
heads have been decked
block has been decked
ROL .045 head gasket
79 J10
Reply #64 on:
January 18, 2010, 01:49:08 PM »
Quote from: cj7fan on January 18, 2010, 12:11:00 PM
Honestly I have no idea somewhere between 8.5 & 9.0. Impossible to tell without actually measuring the CC's of the chambers
Last Edit: January 18, 2010, 01:49:40 PM by mika401
Reply #65 on:
January 18, 2010, 06:02:38 PM »
Is the head gasket thicker or thinner than stock?
Reply #66 on:
January 18, 2010, 08:15:11 PM »
Its a tad thinner not sure by how much
Reply #67 on:
January 18, 2010, 08:17:28 PM »
then with the machining on the block and heads, it seems like it would have a higher compression ratio than stock. not a bad thing.
10-10.5 might be good?
Reply #68 on:
January 18, 2010, 08:40:08 PM »
I seriously doubt its that high, I'd say 9.0 max, and no its never a bad thing these AMC motors really need a bump in compression
navman 5.0
Reply #69 on:
January 19, 2010, 03:25:33 PM »
Running a carb or going to injection?
Reply #70 on:
January 19, 2010, 03:30:40 PM »
^^ wondering the same thing.
However, I'm sure that Miguel is done with carbs.
Reply #71 on:
January 19, 2010, 08:00:37 PM »
Will be going with another projection kit like the one on the red Jeep.
I know these things a pieces of sh!t but its been working on the red Jeep and I had the system on the shelf so why not give it a try. If it doesnt work I'll probably give a GM TBI junkyard set-up a try.
So this is where we stand, intake is bolted down, Edelbrock headers are bolted on, throtle body is on, motor is primed, roller rockers adjusted, all I need to do now is hook it up to the tranny and drop it in.
Reply #72 on:
January 19, 2010, 08:04:16 PM »
Hydro steering I assume? Will you be using double ended or single ended rams?
jason m
Reply #73 on:
January 19, 2010, 08:36:38 PM »
Single. There simple to set up and cheap to buy. Probally just get a few of the 2" boar 1 1/8" chrome rod tractor rams like on the Jeep. Bolth of us are going to use some 2" solid 7075 ALU for tie rods. Thats ALU is like a rubber band, you hit it and it bounces back.
I was a busiy bee today, I got alot of the lower link tabs made. I'm not happy with one set I made so tonight ( If I'm feeling better ) I might make a hole new set. No worry I will use those on my axle's
Jason.
Reply #74 on:
January 19, 2010, 08:52:55 PM »
What happened? what dont you like about them?
4
5
6
7
8
44
My buggy build
