January 16, 2018, 06:06:22 PM
Author Topic: Our 71 Pontiac T-37 build  (Read 46223 times)
Re: Our 71 Pontiac T-37 build
« Reply #30 on: August 23, 2009, 09:48:50 AM »
The 428 block is on its way to me. ;)
« Reply #31 on: August 25, 2009, 02:06:29 PM »
here it is;
« Reply #32 on: August 25, 2009, 02:23:22 PM »
wow cool. how much was that thing!
Offline cj7fan
« Reply #33 on: August 25, 2009, 03:17:27 PM »
Nice Bob.......... ;D
My advice... invest in rubber.   :burnout:
Kent
Jetboat - Finished!!
« Reply #34 on: August 25, 2009, 04:48:44 PM »
Bling Bling........Vroom Vroom
« Reply #35 on: August 25, 2009, 05:02:08 PM »
It is a 69 428ci hot tanked and magna-fluxed, $400 .
« Reply #36 on: August 25, 2009, 05:20:31 PM »
Good deal, who's gonna do the machining and assembally? I would love to help you with the assembally  ;)
« Reply #37 on: August 25, 2009, 07:28:22 PM »
A local machine shop will do the machine work, I (and Lynn, since its her car ;))will do the assembly.
« Last Edit: August 25, 2009, 07:40:05 PM by Axle »
  • Administrator
« Reply #38 on: August 26, 2009, 05:49:55 AM »
LUCKY!
Jeep-less and grumpy.
Offline Toreadorranger
« Reply #39 on: August 27, 2009, 10:25:44 AM »
Is it a 2 bolt or 4 bolt motor?
2000 Ford Ranger Crawler Project
« Reply #40 on: August 27, 2009, 10:43:44 AM »
alot of the pontiacs were drilled and tapped for 4.(this one has the holes & is tapped already) It came with 2 bolt caps, but I will be adding the 4 bolt caps.
« Reply #41 on: August 27, 2009, 10:47:51 AM »
bob, i bet you could fit that in the cj ;)
« Reply #42 on: August 27, 2009, 12:12:03 PM »
Is it standard bore?
What compression will you be running?
Fuel injection or carb?
« Reply #43 on: August 27, 2009, 12:19:58 PM »
It will be .030" over with a longer stroke crank (4.250"). Depending on the heads we choose, I'm looking for about 11:1. this is the kit I am leaning towards;
http://www.speedomotive.com/ps-146-16-pontiac-428cid-to-467cid-stroker-kit.aspx
« Reply #44 on: August 27, 2009, 12:39:03 PM »
Flat tops nice.
Thats allot of compression, dont think regular gas will do.  Might have to go with race fuel, what do you think?
