January 16, 2018, 05:58:41 PM
Author Topic: Our 71 Pontiac T-37 build  (Read 46222 times)
Re: Our 71 Pontiac T-37 build
« Reply #300 on: February 27, 2014, 04:28:24 PM »
Awesome Bob.  Was the 12 bolt original to this chassis?
« Reply #301 on: February 27, 2014, 04:37:02 PM »
no, this car was a 10 bolt, 350 2 barrel
Offline XJFever
« Reply #302 on: February 27, 2014, 06:12:04 PM »
get this thing ready for the summer nationals so I can take pics with this new fancy DSLR the wife bought me.!
« Reply #303 on: February 27, 2014, 06:45:46 PM »
i need a bag of money
« Reply #304 on: February 27, 2014, 08:36:39 PM »
Bob, your tires are already off the ground real easy to check the gearing unless there is a need to change the fluid.
Mark the tire at the 6:00 position with some tape or chock, then mark the driveshaft. Turn the tire exactly 1 full turn (posi diff). Count the number of times the driveshaft turns.
2-3/4 turns of the driveshaft = 2.73, just past 3 turns = 3.08, 3-1/3 = 3.31, just past 3-1/2 = 3.55, 3-3/4 = 3.73, just past 4 = 4.10 or 4.11.
Looking good!
« Reply #305 on: February 27, 2014, 09:03:15 PM »
Regarding gearing, and assuming the gearing is stock GM... It could be anywhere from 2.72 to 3.73 unless it came from a COPO type car (yenko, baldwin motion etc..)it came with 4.11 gears.  Use the spin the yoke to tire method to get you into the ball park.
Edit ^^like that^^ Thanks Posi
« Last Edit: February 27, 2014, 09:04:43 PM by jps4jeep »
« Reply #306 on: February 28, 2014, 08:20:43 AM »
i would like to see inside anyhow. but thanks guys.so far, very happy with this car, just want it to move under its own power.  :D
« Reply #307 on: February 28, 2014, 08:33:39 AM »
love to hear it!!
« Reply #308 on: March 02, 2014, 12:08:29 PM »
Have you sat in the drivers seat yet and made engine noises?
« Reply #309 on: March 02, 2014, 01:22:19 PM »
 :D  :burnout:
« Reply #310 on: April 09, 2014, 10:07:07 AM »
looks like 3-1/3 = 3.31
« Reply #311 on: March 13, 2016, 06:07:50 PM »
have not updated in a while. getting the wiring finished up. Installing the Hooker super comp 2" tube headers was a pain in the ass. a little grinding and removing the starter, oil filter housing and busting my but to get to some of the header bolts, and both sides are finally in. the ac stuff was getting in the way as well, so the decision was made to scrap it. I found a company that makes a new heater box that allows me to still have heat and defrost as well as looks appropriate on the firewall. fender had to removed in order to swap the ac out, kinda thinking I should have taken the nose off long ago, much easier to do things.
« Reply #312 on: March 14, 2016, 06:05:48 AM »
 8)
« Reply #313 on: March 14, 2016, 05:27:00 PM »
 8)
Leaf sprung people matter
« Reply #314 on: March 14, 2016, 06:01:12 PM »
 8)
