January 16, 2018, 06:10:02 PM
Author Topic: Our 71 Pontiac T-37 build  (Read 46224 times)
Re: Our 71 Pontiac T-37 build
« Reply #45 on: August 27, 2009, 02:49:06 PM »
Mabye. :D Maybe I'll go 10:1?
  • Trails Coordinator
« Reply #46 on: August 27, 2009, 08:20:34 PM »
what kind of torque and hp do you think she'll make ?
« Reply #47 on: August 27, 2009, 08:51:24 PM »
Umm, it was 375 stock, so I don't know, near 500?
« Reply #48 on: August 28, 2009, 11:31:13 AM »
sounds like fun..i'd like a big block camaro some day.
« Reply #49 on: August 31, 2009, 04:13:34 PM »
Went to NEdragway Sunday for a swap meet, but all I got was a timing chain cover.  ::)
« Reply #50 on: August 31, 2009, 05:19:26 PM »
I have a couple motor sources, is there something in particular you are looking for?
« Reply #51 on: August 31, 2009, 08:02:57 PM »
around 87cc heads, 4 bolt main caps, intake, roller rockers, push rods, carb, valve covers air cleaner, and lots 'o little stuff. some of this I will buy new, depends what I find for deals.
« Reply #52 on: September 01, 2009, 08:00:23 AM »
97 CC heads????  forced induction or 87 pump gas?
« Reply #53 on: September 01, 2009, 08:02:30 AM »
what are you asking?
« Reply #54 on: September 01, 2009, 08:09:58 AM »
ment 87 cc, depending on the piston used, you could ideally keep the compression ratio around 9.XX:1 which would give you a nice flowing head, that can take a couple lb's of boost no problem   or   you could build a great cruising engine with a low compression able to run 87-89 pump gas and still have plenty of punch.
« Reply #55 on: September 01, 2009, 09:07:15 AM »
With the 87cc heads and the pistons I am going to use, it will be about a 10.4:1 . witch should be a good comprimise for street/strip type driving.
« Reply #56 on: September 01, 2009, 10:46:10 AM »
I wasn't criticizing, just wondering. with a 87 cc head, your options are pretty endless, it's not like your committing to a 93 or 84 cc head that would be more ideal to a specific induction system. the only limitation you are really setting is being reliant on 89-93 octane, (big deal huh)  I am loving this project...
« Reply #57 on: September 01, 2009, 10:50:21 AM »
I understand, thanks . Looking into some alluminum heads.
« Reply #58 on: September 01, 2009, 10:59:20 AM »
Edelbrock has a nice Alum head line, but pricey!!
« Reply #59 on: September 01, 2009, 12:19:18 PM »
I found a set for less than half. And they came with roller rockers and push rods. pics to come.
