May 25, 2012, 01:22:17 AM *
Pages: 1 [2] 3 4 5   Go Down
Author Topic: Prodject Queer steer  (Read 3113 times)
jason m
« Reply #15 on: December 11, 2009, 06:26:14 PM »
How come there doesn't appear to much dirt/metal shavings under the axle?  Whenever I work there is black steel/iron dust EVERYWHERE!
Teach me your method!! Grin
Dumb question, but this is going in the YJ, correct?
Yep going into the YJ.
I normally put the axle on a cart or my pallet jack and roll it out side into the driveway or the side of the house and do all the grinding out side. But i do grind alot inside the house, but seeing how its a under the house ( the garage ) I'm allways sweeping the floor. This way i dont track it threw the house and i go as far as changing cloths before i come upstairs.
My wife breaks out in rash's if she touchs the grinding grit or any metal shavings. Me Ive been doing it for clsoe to 20 years now i pee iron flake's Grin
Jason.
Zaedock
« Reply #16 on: December 11, 2009, 06:48:00 PM »
The result of going queer steer.
'92 YJ  7" Lift  2.5L/SM420/NP231HD
38" Mickey Thompson Claws  Full Cage Winch
« Reply #17 on: December 12, 2009, 08:41:51 AM »
Looks good Jason!
derickw
« Reply #18 on: December 12, 2009, 11:57:03 AM »
i have to do everything in my 8x10 shed. its not bad just have to keep an eye on the sparks. the worst is everything getting up my nose. i suppose a mask might help but whatever.
jason m
« Reply #19 on: December 12, 2009, 12:25:24 PM »
Thanks guys, more to come later. I want to get my Hobo steering arms on and drilled today, then i can ream them as i still have Miguels TRE reamer Grin
Jason.
« Reply #20 on: December 12, 2009, 01:11:35 PM »
See told you there was something else of mine in that black hole of yours  Shocked
jason m
« Reply #21 on: December 12, 2009, 02:49:34 PM »
Ya i saw it in the bottom of the red box the other day and said OHHH i can use that.
Jason.
jason m
« Reply #22 on: May 03, 2011, 11:21:27 PM »
Well its time to dust off this thread with some progress. I had alot of work this winter and it was mostly outside work, so when I got home and dealing with the snow and wood stove it really sucked the life out of me.
So after getting back out on the trail the other day and seeing how I don't have a rear 14 bolt left in my Jeep I need to get this done and on the trail. So I got some progress done over the last few days and will post pics when I take some.
Jason.
jason m
« Reply #23 on: July 12, 2011, 10:18:30 PM »
Update, yes this along with alot of other prodjects ( cutting and spliting Tornado wood ) is taking the normall to much time but heres some Pics of where I'm at.
Axle installed for mock up,
Using the OEM low steer arm but in double sheer,
another and thats a piece of 2" .250 wall DOM steering tube, should be enough,
Front with a 2x3 tube truss welded to the center section,
You can see the welded diff in that last pic and I'm going with the same style off the OEM arm steering for now. Over the winter I will make my own arms and tie them in.
More to come, but life allways has a way of slowing down the fun stuff.
Jason.
« Reply #24 on: July 12, 2011, 10:58:40 PM »
looks good Jason.  As always...so do those welds. You do lay one hel of a bead man Salute
« Reply #25 on: July 12, 2011, 11:10:40 PM »
Its alive!!!!
Nice to see this moving along...
05rckymtn
« Reply #26 on: July 13, 2011, 09:34:33 AM »
Schweet. Was does the hole in the 2x do for ya?
« Reply #27 on: July 13, 2011, 10:01:28 AM »
Hole for bullets so he can shoot the rocks when he cant get over them
« Reply #28 on: July 13, 2011, 01:35:39 PM »
i forgot you even had a rig!     whip
« Reply #29 on: July 13, 2011, 03:33:49 PM »
Ouch!!!
Pages: 1 [2] 3 4 5   Go Up
