« Reply #285 on: May 10, 2010, 11:33:14 PM » |
Thanks!
You have such great attention to detail. Also, did those axles I post up in the for sale section come to your use? Or rather, collection?
Looking good!
« Reply #286 on: May 12, 2010, 07:51:47 AM » |
No, although I would have if they were narrow tracks (30) being their an upgrade for 71 and down. Thanks for posting the axles and comments though.
« Reply #287 on: May 17, 2010, 08:46:15 PM » |
Having a problem with photobucket again. Some of the pics are not showing up on my account of the 7 pics I had planned to post tonight only 3 show on the account. I made no changes to the album or account so I'm sure it's on their end. I checked earlier pages in this thread some pics are there some are not.
I'll make an entry when the pics become available. Sorry about the delay.
« Reply #288 on: May 17, 2010, 09:37:43 PM » |
 Photofuckit has been messing with the wrong MOFO. Do they know who you are?
98 ZJ in progress DD 90 K5 Kubota
« Reply #289 on: May 18, 2010, 07:44:53 AM » |
Their back, I bought some 760x u-joints from Jeff @crown. I used a press to install the u-joints and used a hammer to tap the yoke of the shaft to set the caps. I also replaced the axle shaft seal (dust seal) and added grease around the thrust face of the shaft, seal area of spindle, and valley of the seal.  I greased the inner splines before installing the axle shaft being careful not to dislodge the inner axle seal. I kept the shaft centered until the shaft splines engaged the side gears then pushed the shaft in. I replaced the needle bearings in both spindles and greased them before installing. I used loctite and torque the spindle nuts to 30 ft lbs   I had two backing plates to choose from the wagon plate is a two piece plate with a caliber bracket and thin dust shield tacked on. The chevy plate is one solid piece and weighs twice as much as the wagon plate. I went with the chevy plate which should last a lot longer.
« Reply #290 on: May 18, 2010, 09:49:16 AM » |
What is the purpose of the backing plate? It just seems like extra stuff to me.
« Reply #291 on: May 18, 2010, 10:37:35 AM » |
dust shield?
« Reply #292 on: May 18, 2010, 10:39:00 AM » |
The purpose of the backing plates is to protect the inside surface of the disc from rocks and other debris. It also acts as a bracket for the caliber. The Jeep 44 backing plate would be useless at protecting the disc off-road but the chevy plate is 1/4” thick and would be useful as a skid, plus it’s free.
« Reply #293 on: May 18, 2010, 11:22:00 AM » |
I see. I didn't catch the part about the caliper mounting.
« Reply #294 on: May 19, 2010, 07:50:27 AM » |
I suggest cutting off the dust shield, when I first built my 44 I ran a dust shield, I kept getting pebbles and debris behind it and it scored the first set of rotors pretty bad. I just cut off what was not desired and retained what is needed.
« Reply #295 on: May 24, 2010, 08:13:31 PM » |
I gave the above statement some thought, pebbles/debris scoring the inside of the disc or rocks/debris scoring the outside of the disc. I believe the chances are higher that a stick could get trapped between the backing plate and disc. Off went the chevy backing plates. I decided to use the Jeep bracket/dust shield and save the chevy plate for another project. I ground down the two spot welds from the brackets and mounted them. Before installing the hub the bracket will get another coat of paint.  I installed new inner cups and bearings into the ford hubs I used a brass punch to install the cups by tapping around the top until it seated. I made sure to clean up any small splinters of brass that tend to come of the drift.  After filling the bearing with grease I installed a new inner seal I made sure to coat the outside edge with Super 300 I used a block of wood and hammer to tap the seal in.  After mounting the hub and rotor I installed the bearing adjuster inner locking nut making sure the peg (located on one side) was facing away from the bearing. I mounted the wheel and rotated it while I tightened the locknut to 50 ft lbs (rotating the wheel helps seat the bearings uniformly). Once the bearings were seated I loosened the locknut and retighten to 35 ft lbs then backed off about 1/3 turn. I then installed the retaining washer making sure to engage the peg on the inner locking nut into one of several holes on the washer. I tightened the outer locking nut to 55 ft lbs. The hub will see another coat of paint as well.
« Reply #296 on: May 31, 2010, 09:20:20 PM » |
I bought a new set of warn locking hubs for $85 shipped and decided to keep my used set I found at the pick and pull for spares.  The installation is straight forward and simple. I first slid in the locking hub body assembly.  Next is the large lock ring into the recess in hub housing.  I used a screwdriver to pry the shaft outbound a bit to give me enough clearance to installed the axle retaining ring.   I turned the cap to the free position and used anti-seize on the screws then installed the cap.
« Reply #297 on: May 31, 2010, 09:55:53 PM » |
man those locking wire spring rings can be a nut buster to get out. I did a set of axles and balljoints a few months back and it was the first time I was intruduced to that type of setup. I quickly found use of the new set of picks I bought. Made that job so much easier. installation is a breeze just pop them in but getting them out on those Ford hubs anyway was a biotch. It was a 1995 F150 I am refering too. Your application looks like they are easier to access than the one I did. You could barely even see the rings and there was maybe 1/8" of room to get in there to work them out. Really coming together nicely Posi!
« Reply #298 on: June 07, 2010, 09:37:21 PM » |
Thanks Rich, Bought a new set of calipers for $14 and shot a coat of high heat blue on them. I also added some semi-metallic pads for $20, kinda odd pads being more then calipers but it is what it is.  All 4 on the ground
« Reply #299 on: June 07, 2010, 09:56:56 PM » |
Wow its coming together real nicely, I've always loved those rims by the way.
