December 15, 2017, 01:37:32 AM
Author Topic: spyder III begins  (Read 13950 times)
  • Event Coordinator
Re: spyder III begins
« Reply #135 on: October 17, 2017, 12:44:30 PM »
if you are worried about combined systems and electric then this is the way to go, but likely a lot more work.
« Reply #136 on: October 17, 2017, 04:26:45 PM »
I could but I'm trying to make it so once the kill switch is thrown. There is nothing electrical on for that in case of emergency o [censored] moment. Right now the only thing directly on the battery is the winch.
I'd love to do the tcase brake but id have to cut my floor to clear it.  Since the tcase already hits the floor
« Last Edit: October 17, 2017, 04:27:56 PM by SPYDER »
« Reply #137 on: October 19, 2017, 07:34:43 AM »
What I have planned for my rear, and mine will be set up more for cutting brake purpose, but can definately be used as a  park brake. I am going to use something similar to what Chuck posted, I have two older ones from parker from fork trucks.  I plan on routing the rear line to a tee, a line will run through each valve to the rear calipers as normal. Basically you press on teh brakes and flip the valve and that caliper is locked.  You can do this with a single valve and actuate both calipers.  The best part of this system is super simple to plumb and diagnose any issues, super easy to bleed the brakes with as they are essentially a free flowing ball valve and does not need any voltage to operate or hold.
« Reply #138 on: October 19, 2017, 07:39:39 PM »
Run a hard line into the passenger compartment and splice in a 6” rubber hose.
Step on brakes.
Apply vise grips to hose.
Profit?
 ;D
« Last Edit: October 19, 2017, 07:39:51 PM by Twisty »
« Reply #139 on: October 19, 2017, 08:13:07 PM »
Lol.  That's a good one.  I think I'm going to do something like what Bob posted. Just trying to decide if I should do both front and rear or just rear.
« Reply #140 on: October 27, 2017, 06:11:01 PM »
Truss is fixed.  Cut the tube that went to the top of the pumpkin and found the welds were completely broken.  And there was no penetration at all.  Well. It's all reinforced and braced properly now.  Looks odd but it isn't going anywhere.
Also ordered a locking, cutting brake that I'm going to use as a parking brake.  Should be interesting...something like this
http://www.madhornets.com/hydraulic-drift-e-brake-racing-handbrake-vertical-horizontal-aluminium-red/?utm_medium=googleshopping&utm_source=bc&gclid=CjwKCAjwssvPBRBBEiwASFoVd8jxXGyFFOzLhcccqzDCOz8U0vwZNnfahacsVu0vWEx0wxrQ27OMphoC_vUQAvD_BwE
« Last Edit: October 27, 2017, 06:15:43 PM by SPYDER »
  • Event Coordinator
« Reply #141 on: October 27, 2017, 08:52:22 PM »
DRIFTING!!!!!
« Reply #142 on: October 28, 2017, 04:49:41 AM »
Step on brakes.
Profit?
 ;D
Come on Tim , that’s hack
And that’s coming from me
« Last Edit: October 28, 2017, 04:50:50 AM by rich »
Leaf sprung people matter
« Reply #143 on: October 28, 2017, 09:59:48 AM »
Step on brakes.
Profit?
 ;D
https://youtu.be/pWdd6_ZxX8c
« Reply #144 on: October 28, 2017, 05:27:34 PM »
Yea. You know. I'm gonna like drift it too.
Pulled it onto the trailer to bring it home today and broke the bolt holding the ram to the knuckle.   Hmmm
