May 19, 2012, 09:48:18 AM *
Pages: 1 ... 35 36 37 [38] 39 40   Go Down
Author Topic: Thriller MJ  (Read 17861 times)
0 Members and 3 Guests are viewing this topic.
« Reply #555 on: November 07, 2011, 05:20:55 PM »
Another thing I learned was that with my tools, 10 gallons of gas and 450-500lbs of people, my rear shocks bottomed out frequently, and only had a few inches of uptravel.  Before this weekend I was already 50ml over the stock fluid level.  Tonight I added around 20ml more.  This means that the shocks are completely full of fluid when compressed all the way.  I made sure that they would not hydro-lock, and topped them off with 100psi of nitrogen.  I'm hoping that this will help or even fix the bottoming out issue.
« Reply #556 on: November 07, 2011, 08:53:21 PM »
It sounds like its gonna be trial and error. Your rig was great Saturday, nice job Tim !
« Reply #557 on: November 08, 2011, 10:28:55 AM »
Yes, I think it will be.
Thanks jerry.  It was great wheeling with you.  Sorry about your tub.  Sad.
« Reply #558 on: March 05, 2012, 01:04:27 PM »
I'm suck of no exhaust.  I ordered this muffler and a bunch of tubing and other stuff.
 http://www.summitracing.com/parts/flo-325108
« Reply #559 on: March 05, 2012, 01:17:11 PM »
Oh boy, I remember that muffler. Wait what? what? huh? I can't hear you!
« Reply #560 on: March 05, 2012, 01:21:13 PM »
its so small!  Woot!
mattamd_xp
« Reply #561 on: March 05, 2012, 03:14:22 PM »
Can that really even be called a muffler???  Grin
« Reply #562 on: March 05, 2012, 05:46:57 PM »
It's better than what I have now, and given my space concerns I hope it will work.
navman 5.0
« Reply #563 on: March 05, 2012, 11:31:42 PM »
Snowmobiles have already been faced with trail loses caused by loud exhaust, I'm sure we will be faced with it too with trail locations becoming closer and closer to residential areas. Noise is one of the few things causing all the problems with swanzey. I thing we as a whole should be more proactive on this.
« Reply #564 on: March 06, 2012, 09:24:17 AM »
So, are you saying that I bought a piece of Censored, and that I need to do better?
Or are you saying that it's a good thing that I'm trying to make the MJ quieter?
 Huh Huh Huh
I listened to quite a few youtube clips of the Flowmaster 10 series, and the Cherry Bomb extreme.  They both sound raspy, but not obnoxious on the 4.0.  Granted, it is youtube, and video cameras are hardly capable of capturing true sound.  I am after a quiet muffler, that isn't a "straight through" race muffler.  I can't fit a long muffler because I don't have a lot of areas where straight lengths of exhaust tubing will reside.  I also don't have room for a stock muffler, or a Thrush Turbo muffler (which I had before, and which Ian has) is still too big.  I will try this little FM muffler, and if it's too loud, I might add another small straight through race muffler upstream.
« Last Edit: March 06, 2012, 09:27:57 AM by Twisty » Logged
« Reply #565 on: March 06, 2012, 11:09:16 AM »
Twisty you ever hear my jeep after I put on the clayton? I had that same muffler.
« Reply #566 on: March 06, 2012, 01:27:06 PM »
No, I did not.
navman 5.0
« Reply #567 on: March 06, 2012, 01:38:21 PM »
I'm glad you are. Many of the new trails are closer to residential areas now and some of the old regulars are  getting built up around. I just think its something we should all keep in mind. Seeing a muffler being added to your build is a good example.
« Reply #568 on: March 07, 2012, 02:43:34 PM »
Flowmaster makes a hushpower as well, which is pretty throaty, smaller case size as well. The 10 series is not quiet by any means, slightly quieter than wide open. It was completely obnoxious in my jeep honestly.
« Reply #569 on: March 07, 2012, 02:44:07 PM »
JJ also ran that muffler on his TJ at one time.
Pages: 1 ... 35 36 37 [38] 39 40   Go Up
