May 19, 2012, 09:49:04 AM *
Author Topic: steves 86 toyota 4runner  (Read 1560 times)
Steve-O
« on: November 12, 2010, 10:18:42 AM »
i told tim last night over at ians that i would post my build over here
this is how i bought it in febuary of 07.  it was a 1986 4runner with 227k on it 22re w56 ifs front with a toy 8in in the rear
needed an fair amount of rust repair but the motor ran great
rebuilt a 1985 toyota solid front axle for it
started  to clean up the frame
ifs coming out
my working conditions at the time  Cheesy
front hanger welded on and more frame refinishing
sitting back on all fours
cut the rear fenders for more clearance
we cut 3.5 in off the body and then sectioned the fender well and rewelded it to the body
made a poop pipe front bumper
im skipping a little bit here but nothing too important,  this was by far my favoret stage of the truck i drove it every where (including rausch) made rear bumper and sliders still open open
new england toyotaz?
« Reply #1 on: November 12, 2010, 10:28:19 AM »
It doesn't look like that anymore.   Grin
I love this truck!!  Thanks for posting, Steve-O!!
« Reply #2 on: November 12, 2010, 10:28:34 AM »
nice!
« Reply #3 on: November 12, 2010, 10:29:38 AM »
awesome
Steve-O
« Reply #4 on: November 12, 2010, 11:07:36 AM »
made some half doors
added a crawler
and put a detroit in the rear
little more body protection
made a hd t case mount
:great:
started a poop pipe cage
the two diagonal tubeson the side and the two black tubes are just bracing while i finish weld it :great:
exo all done
flopped it at mabell
rolling it back
<a href="http://i43.photobucket.com/player.swf?file=http://vid43.photobucket.com/albums/e356/cpsavinski/Mabell%204-06-08/DSCF0440.flv" target="_blank">http://i43.photobucket.com/player.swf?file=http://vid43.photobucket.com/albums/e356/cpsavinski/Mabell%204-06-08/DSCF0440.flv</a>
and the damage
just call me stubby
 :runscream: :runscream:
almost done :great:
n
36x12.5x15 tsl sx on and wheeled for a while
Steve-O
« Reply #5 on: November 12, 2010, 11:27:58 AM »
here is where the funs stuff starts
custom 61in wms toy front
[/quote]
pinions a little high
temp cut and sleeved tierod
so made a "flat" belly pan yesturday,  the pan is flat but it hangs down 2in below the frame
started out making this crossmember it is .25 wall 2x2 and welded to the frame
then i made this crossmember to go over the driveshaft,  also .25 2x2
it is still possible to get the tcase and tranny out with these welded in its just going to be a Censored :laugh:
next i connected the two crossmembers with some 2in angle and made a little sub stucture that bolts in to support the pan
and i will be using this as the pan
3/8 thick peice of poly (basicly a cutting board)
linked the rear
got sick of the Censored up cage in the front and the mashed panels so i pulled a chad and got the sawsall :laugh:
got the truck in the garage for a 3 linked front and a new motor
its gettig a new front clip, new front half of the cage, and a new front bumper, going to put in the 3rz finally, and i orderd all the parts to do a front 3link because im sick of the leaves
front axle out
got the frame all cleaned up
the 3rz waiting to go it
spent a couplehours at the shop
got the motor mocked in
new motor mounts
made some frame reinforcment plates
motor is in  :great: it sits about 3/4 of a inch higher than stock
motor mounts
plenty of space in the intake side but the exhaust side is a little tight
frame plates all burned in
front crossmember in
ruffstuff sent me the wrong misalingment spacers so i  had to drill all my 9/16 tabs to 5/8 :doh:
got all the link brackets mocked up/made
my home made lower mounts
changed my mind again :laugh:
decidd to move my upper in a few inches closer to the diff
frame mount for upper
mounts all tacked in
Steve-O
« Reply #6 on: November 12, 2010, 11:42:35 AM »
all tacked in with temp sch 40 links,  took allot off adjusting but it clears so far.  i have been cycling it all day
i was able to move the lowers out a little more but if i go any farther then the tires are going to rub them
gave up on wiring for a bit
got most of the 3 link done
its really tight on the driver side at full lock but it clears
shock towers done
engine bay shot
ecu hidden away
little bit more loom and im done with wireing
took a couple of nicer daylight pics
started my front bumper tonight too
im going cut the grill and some of the rad support to fit the winch in
put a third coat of paint on everything,  did my front brakes and started the winch mount
and just incase any one didnt notice my new nose and many other parts came off jays old 4runner so it can live on in mine a little
front is sitting a little taller than i would like but i got the front fenders cut
mounted my optima in the back
vids of the motor
<a href="http://i111.photobucket.com/player.swf?file=http://vid111.photobucket.com/albums/n123/sneakyjoe9988/86%204runner/rebuild%2010-09/105_0657.flv" target="_blank">http://i111.photobucket.com/player.swf?file=http://vid111.photobucket.com/albums/n123/sneakyjoe9988/86%204runner/rebuild%2010-09/105_0657.flv</a>
<a href="http://i111.photobucket.com/player.swf?file=http://vid111.photobucket.com/albums/n123/sneakyjoe9988/86%204runner/rebuild%2010-09/105_0662.flv" target="_blank">http://i111.photobucket.com/player.swf?file=http://vid111.photobucket.com/albums/n123/sneakyjoe9988/86%204runner/rebuild%2010-09/105_0662.flv</a>
and here is the most current project
so i drove down to RI to help a freind get her 69 z28 running again and noticed a pickup sitting in the woods behind her house,  after getting the car running i asked her what was going on with it and she said the have been meaning to junk it for years now and if i want it i can have it
not in any rush but now i have them for down the road  Evil
« Reply #7 on: November 12, 2010, 12:21:22 PM »
wow Steve-o nice write up.  Cool yota
« Reply #8 on: November 12, 2010, 12:28:36 PM »
your lathe?
Steve-O
« Reply #9 on: November 12, 2010, 12:53:13 PM »
no it is a freinds lathe
got the rear done now im working on rebuilding the front,  it is 100% wheelable right now other than i gotta buy some more lug nuts
ff14 bolt with 4.10s welded with disc brakes
here is the front just starting to tear it down
« Reply #10 on: November 12, 2010, 02:34:36 PM »
You posted so many pics it crashed my laptop.   Roll Eyes
Thanks for posting the pics.  You've put a lot of work into that truck. Cool Cool Cool
dips
« Reply #11 on: November 12, 2010, 03:55:35 PM »
 Grin
05 TJ  3 link front, 4 link rear  16" air shocks on 4 corners  5.13's spooled f&r  38"sx  108" wheelbase
« Reply #12 on: November 12, 2010, 09:04:14 PM »
I must of just missed you last night,   Looks good!
what are you doing with the old Yota axles?
Steve-O
« Reply #13 on: November 12, 2010, 11:07:40 PM »
not sure yet.  i would love to put to gether a single seat toy moon buggy but ill probally just sell them
« Reply #14 on: November 12, 2010, 11:55:11 PM »
Did you have to have custom axle shafts made for the widened front?
