May 22, 2012, 10:14:34 PM *
Author Topic: Some YJ parts  (Read 810 times)
RustedWrangler
« on: March 10, 2011, 09:40:13 AM »
Making some room and thought someone could use these parts.
Stock YJ parts:
3- stock tail lamps. Two of them are off my Jeep, one is a parts store lamp. The two off my Jeep have smoked out lenses. Pigtails were cut to use with new lamps, but these worked fine before I removed them.
1- cracked exhaust manifold and new gasket. This could be welded and used to get you by.
1- D30 cover with drain plug
1- 20 gallon poly tank
1- stock battery hold down
1- windshield stand off for hood (only one, not pair)
1- metal tailgate stop
1- stock height radiator support (goes on side of grill to frame)
1- cigarette lighter/ashtray housing (no lighter or tray)
1- spare tire carrier for tail gate
Non YJ:
1- Thrush turbo muffler, good shape, 2 1/4" in 2 1/4" out
1- Napa locking choke cable
2- small speaker boxes powered by head unit. Worked well in my Jeep for about a year then the head unit went out. Don't know if working 100%.
1- 40Wx2 channel power amplifier
1- air conditioner compressor off a grand cherokee (I6)
2- Willy's style side mirrors
« Last Edit: May 30, 2011, 09:14:06 AM by RustedWrangler » Logged
91 YJ
« Reply #1 on: March 10, 2011, 09:56:43 AM »
I will take the muffler.
« Reply #2 on: March 10, 2011, 10:20:31 AM »
where are you located? insterested in the poly gas tank, is it bare or w/ pump? Stock configuration? Year?
Any idea if it works in an XJ?
RustedWrangler
« Reply #3 on: March 10, 2011, 10:36:09 AM »
Of course dude!
I'm in Ipswich, MA.
The tank is stock, out of Dave's YJ which I believe is a 4 cylinder. I pulled the pump to use in my tank but I still have the vent plugs with assoc. hoses, top metal piece and I think the screws that hold the pump in. I'm not sure about the year or if it would work in a cherokee.
I can always bring the stuff to the next trail run or meet up before then. Just let me know!
91 YJ
« Reply #4 on: March 10, 2011, 11:06:07 AM »
ill confirm with jeff (crown) I think he knows the answer and let you know.
« Reply #5 on: March 10, 2011, 02:51:35 PM »
Dibs on the choke cable and the mirrors please.
« Reply #6 on: March 10, 2011, 09:05:17 PM »
Put me in line for the mirrors
« Reply #7 on: March 10, 2011, 09:21:54 PM »
Fingers
« Reply #8 on: March 11, 2011, 09:07:47 AM »
If it is Willy's as in jeep willys, give them to jerry, if is it willys as in buisness man coupe.. F-Jerry and give them to me.
« Reply #9 on: March 12, 2011, 10:31:04 PM »
hey john, from the looks of this thread i'm starting to think neither of us are gonna get those mirrors... Shrug
RustedWrangler
« Reply #10 on: March 15, 2011, 09:18:26 PM »
Gas tank- Mitch
Twisty- Muffler
Jerry K- mirrors and choke cable
Jps4jeep-in line for mirrors
Mitch, have you found out more about the tank's compatibility? Either way I took some measurements and the tank is 33" long x 17" wide by 13" tall, not including the fill/vent tubes on the passenger side. It's not a perfect square but if it had to fit in a box it would be about that size.
Twisty- I also measured the muffler. It is 14" long x 11" wide x 4-1/2" thick. The in and out pipes are offset to opposite sides of the muffler.
If you want I can send them in the mail but I figured it would be easier to bring them to a trail ride. Never the less, if it's not convenient for you to go to a trail run and we're too far apart I don't mind sending it. Just let me know what you want to do  Smiley
BTW yes they are Willy's as in the Jeep. With the exception of the mounts they are sturdy little mirrors.
91 YJ
« Reply #11 on: March 15, 2011, 11:59:11 PM »
Sounds good.  Grin....see you at the next run.
« Reply #12 on: March 16, 2011, 07:07:19 AM »
thanks will investigate my side further Smiley
RustedWrangler
« Reply #13 on: May 30, 2011, 09:15:38 AM »
Most of these parts will meet the dumpster by the end of the day so let me know if there's anything you want last minute.
91 YJ
