January 17, 2018, 08:48:57 PM
Author Topic: Framing nailer  (Read 1251 times)
Online Twisty
« Last Edit: July 28, 2014, 03:15:52 PM by Twisty »
Re: Framing nailer
« Reply #1 on: July 28, 2014, 09:19:43 PM »
I have used them all! Shot 1000s of nails through all of them! Currently I use a a bostitch cause my hitachi guns got stolen and I had to buy new guns that day!
I prefer the hitachi above all other guns but for the money the bostitch will serve you fine. I have had mine (replacement bostitch guns) for 6 years now. Thought they would wear out but they just keep working. One is messed up when it is below freezing out, won't fire but the others work fine.
The hitachi guns have better driving force with less recoil and are quieter that is a fact. But then again unless you are shooting a lot of nails you will probably never notice that.
Don't buy ridgid! That sh!t is junk! Home Depot crap!
Good luck
Re: Framing nailer
« Reply #2 on: July 29, 2014, 08:38:38 AM »
im a Bostich fan
Re: Framing nailer
« Reply #3 on: July 29, 2014, 08:42:47 AM »
not much can go wrong with these, used may be a good way to go? from a used tool shop.
Online Twisty
Re: Framing nailer
« Reply #4 on: July 29, 2014, 03:29:25 PM »
I have a line on a used Hitachi.
Thanks jeepgod and Axle.  8)
Re: Framing nailer
« Reply #5 on: July 30, 2014, 05:47:24 AM »
No problem, good luck
Make sure that used gun you are buying works in the cold. Seals go bad and leak, this is more of an issue in the winter. Don't know how you would check that at this time of year but it is a common problem.  Rebuilding a gun is cheap though, seal kits are cheap, and you can do them yourself as long as you take your time. I pay a shop to rebuild my guns. Usually only costs $75 or so. Depends on what is broken but the point is a used gun can work out great
  • Administrator
Re: Framing nailer
« Reply #6 on: August 01, 2014, 06:40:50 AM »
I prefer a Stanley 13oz hammer over anything listed in this thread. Jeepgod can vouch my skills.
Jeep-less and grumpy.
  • Trails Coordinator
Re: Framing nailer
« Reply #7 on: August 01, 2014, 08:30:32 AM »
Haha..I think my little nephews playtime carpenter kit came with a 13 ounce hammer. Now if your doing some fine finish work....
Carbureted people matter
Re: Framing nailer
« Reply #8 on: August 01, 2014, 09:57:21 AM »
Hahaha
Re: Framing nailer
« Reply #9 on: August 01, 2014, 03:35:16 PM »
I can only vouche for your hole digging ability. And I can't say much good about that  :D
