May 24, 2012, 10:26:22 PM *
Author Topic: "Building" a JK (JK Owners help me/provide advice)  (Read 538 times)
« on: July 16, 2010, 08:03:07 PM »
In the next few weeks I'm going to be working on one of my bosses friends new JK. And I know nothing about JK's
He wants to run 33's. Would these be ok with stock gears? its the 3.7L, auto trans. Sport edition.
Can I run a 15" Wheel?
What size lift do I need for 33s on a jk? 2"?
If I use a Budget Boost kit, do I need to address trackbars or sway bars?
Suggestions on good winches? It already has a set of bumpers on it, winch ready. I was thinking superwinch ep9 (whatever?)
Apparently there is a kit to move your EVAP canister underneath, who sells this?
Suggestions for skidplates and where?
Thanks guys! Wish it was a TJ, I wouldnt have to be asking these questions!
« Reply #1 on: July 16, 2010, 09:17:19 PM »
My understanding is, 33" tires tat are 10.5" wide (metric equiv.) will fit stock. a Budget boost just makes them look better, the 3.8 is gutless stock, so little bigger tires won't help, but I would just drive it and not worry about it.
if you go the BB route, install what is comes in the kit, should be enough.
Winches, what ever really, want to pay for a superwinch or a warn, go right ahead, smitty built winches, from what I have read so take it for that, are not bad, presonally I have been hearing good reviews of Gorilla winches. I guess it is a newer company that started out just importing korean crap, but is not making them in america.. again, only internet reading here.
skids.. everything, JK's are not known for being well protected from the factory.
« Reply #2 on: July 16, 2010, 09:37:41 PM »
oh, 15's will not clear the front brakes from what I just googled
« Reply #3 on: July 16, 2010, 09:46:46 PM »
email NE Wrangling, I dont think he comes here much, you could pm him I guess. He build his 4 door up pretty nice, I think he researched a lot too. I work with him and he talked Jeep pretty good.
« Reply #4 on: July 16, 2010, 11:30:54 PM »
Thanks John and Mitch
« Reply #5 on: July 16, 2010, 11:34:44 PM »
from what i have heard the JK's will clear 35's with a BB!!
i do not know this for fact but i think pianoguy was saying that...
maybe he'll chime in??
Crown Automotive - Jeff
Support your local vendors!!!
« Reply #6 on: July 17, 2010, 01:40:59 PM »
JK's can fit 33's stock.
http://www.jeepswag.com/ sells the evap relocation kit, but there are also companies that sell a skid for it. I'd just do the relocation but you can do it/assemble the kit and relocate it yourself very easily.
I know some 15's do work as I've had customers come in with them, but most people just run 16 or 17" wheels. I think with some you have to grind the caliper just a little, but I know others who did nothing and they fit, barely.
The front skids I've heard are generally not necessary. The oil pan skids are a good idea. Not a bad idea to switch to smaller/relocate muffler.
Yes.
jeeptech
« Reply #7 on: July 17, 2010, 09:35:20 PM »
33's will fit if you don't wheel it.  Otherwise you need a BB.  2" will clear 33's for offroad and 3" for 35's.  On autos you may have to notch the trans skid to clear the drive shaft.  You will need a rear track relocation bracket, The front should be OK for 2".  You will need a steering damper the stock ones suck.
« Reply #8 on: July 17, 2010, 11:36:08 PM »
2" BB sounds like it's going to be. Going to run 33s. So def need a trackbar relocation bracket for the rear for that height?
Thanks Chris!
« Reply #9 on: July 20, 2010, 10:06:42 PM »
Just ordered 3 grand worth of Censored. Maybe I'll take some pictures and stuff
« Reply #10 on: July 20, 2010, 10:09:44 PM »
maybe you should! Order extra Censored and dont tell him! then sell on ebay!
« Reply #11 on: July 20, 2010, 11:56:43 PM »
haha amazing.
I got bfg 33's
Procomp wheels
superwinch ep9
KC lights
Front and Rear bumpers (thanks Jeff!)
Skid plates
Evap relocation
Steering stabilizer
what did i forget
« Reply #12 on: July 21, 2010, 06:40:15 AM »
budget boost / body lift?
« Reply #13 on: July 21, 2010, 12:37:50 PM »
teraflex budget boost setup.
navman 5.0
« Reply #14 on: July 21, 2010, 05:20:34 PM »
There's a couple guys in wm4x4 running jk's and they both did front axle inner c gussets. I guess they are weak on the new jk axle design.
