May 24, 2012, 10:30:55 PM *
Author Topic: 1" transfer casedrop QUESTION  (Read 715 times)
oldfart
« on: March 17, 2011, 02:36:23 PM »
Ok thanks for any help in advance. I have a 98 tj. I put a 3" lift in it and I am putting in a 1" drop for the transfer case. Is it normal for the stock bolts to strip all the threads off the frame? It has happened on the first 3 bolts I have taken out. Is this normal and any suggestions on dealing with this problem? Do I tap the frame hole for a bigger bolt? Is there another solution? Sad
« Reply #1 on: March 17, 2011, 02:57:08 PM »
I would make a solid.1" spacer out of flat stock..drill and tap it for the crossmember and then weld it to the frame. You could always cut it off later when u go with a sye and heavier cross member.
« Reply #2 on: March 17, 2011, 03:17:52 PM »
yes. unfortunately it is. Its a TJ thing.  Roll Eyes  IMHO the best methods require welding 3 nuts to a plate and welding that plate to the bottom of the frame.
oldfart
« Reply #3 on: March 17, 2011, 03:30:40 PM »
Bummer! I think I will weld the bolts right to the frame. If that turns out to be too hard I will weld them to a piece of steel like you suggested.
« Reply #4 on: March 17, 2011, 03:50:52 PM »
You can also cut small holes in the side of the frame and do the nut/bolt method.
« Reply #5 on: March 17, 2011, 06:20:39 PM »
I would have skipped the drop, and eventually do a slip yoke eliminator
« Reply #6 on: March 17, 2011, 06:23:41 PM »
X2
« Reply #7 on: March 17, 2011, 07:10:34 PM »
Same but does not negate the frame issue, you'd have to drop the skid to do the sye anyways
« Reply #8 on: March 17, 2011, 07:49:57 PM »
When you do a sye will need a new drive shaft.  Get out of the sport while you can.   Woot!
jeeptech
« Reply #9 on: March 17, 2011, 08:30:15 PM »
Drill straight up through the frame and through bolt it.  you will need a 6-7" bolt and some large washers for the top of the frame and nylock nuts.  This works very well and is fast and easy.  X2 on the SYE.
« Reply #10 on: March 17, 2011, 08:52:10 PM »
x2 on the through bolting  Grin
RustedWrangler
« Reply #11 on: March 18, 2011, 11:59:36 AM »
YJ thing too  Grin
My threaded inserts, rivnuts, nutserts, whatever you call them stripped out as well but the bottom section of my frame was good and rusty so I took the opportunity to weld in some 3/16" angle.
You can buy new inserts from Fastenal.
91 YJ
oldfart
« Reply #12 on: March 18, 2011, 01:33:35 PM »
Well I drilled 1 1/4" holes in the frame so I could get a nut and a wrench inside. Then used 1/2' bolts and it worked like a charm.
« Reply #13 on: March 18, 2011, 02:56:33 PM »
congrats.  i'd plan on all of those nuts rusting away in the future.
« Reply #14 on: March 18, 2011, 03:23:31 PM »
I dont think so.
