May 24, 2012, 10:31:58 PM
1 ton TRE taper
Topic: 1 ton TRE taper (Read 422 times)
1 ton TRE taper
June 13, 2011, 10:24:53 AM »
Does anyone offhand know what the taper is for the 1 ton chevy TRE (pn ES2027L for example) it is a 3/4" taper? need to buy a new reamer.
Re: 1 ton TRE taper
June 13, 2011, 11:39:22 AM »
I think the taper is 1.5"/foot?
Re: 1 ton TRE taper
June 13, 2011, 02:43:29 PM »
U R correct, had some time to search for it today, found one, might look around and see what McMaster Carr is getting for one.
http://completeoffroad.com/i-122857-reamer-tie-rod-made-in-u-s-a.html
1 ton TRE taper
