May 24, 2012, 10:38:33 PM *
Author Topic: 3wd investigation  (Read 275 times)
« on: August 15, 2011, 01:56:40 PM »
tore into the jeep today, the lock right pins were broke, and the collar piece was broke as well. new spartan on the way. bbq here I come!  Cheesy
« Reply #1 on: August 15, 2011, 01:59:06 PM »
nice bob!  atleast it was an easy fix!
derickw
« Reply #2 on: August 15, 2011, 02:49:16 PM »
nice, glad it was an easy fix. good to see it didn't slow you down much in NH
« Reply #3 on: August 15, 2011, 03:21:10 PM »
When I re-geared my front 44 my lock rite was toast as well. I replaced it with a Spartan, I have no complaints so far.
« Reply #4 on: August 15, 2011, 04:32:24 PM »
 are those lockrite parts worth hanging onto for spare? If so don't throw them  same locker I have no?
« Reply #5 on: August 15, 2011, 06:02:21 PM »
correct. spare stuff.
« Reply #6 on: August 17, 2011, 02:48:24 PM »
Recieved the Spartan, looks like an improved design compared to the lock right. larger pins, easier install. Once I figured out that the thrust washers don't get used.  Roll Eyes
« Reply #7 on: August 17, 2011, 03:12:55 PM »
I know this doesn't help now but it was there if needed.
http://newenglandjeepz.org/forum/builds/project-5/msg73889/#msg73889
« Reply #8 on: August 17, 2011, 03:14:54 PM »
I just  posted on that thread.  Cheesy I don't think as clear as you Chuck.  Cheesy Hahaha its in now. How did you know not to use the thrust washers? It didn't mention it in the instructions?
« Reply #9 on: August 17, 2011, 03:21:59 PM »
The instructions steps never mention to "install" the thrust washer. A more helpful set of instructions would state "do not install original thrust washers".
Edit: Good to hear the locker is in, I'm sure you will like it.
« Last Edit: August 17, 2011, 03:27:12 PM by Posimoto » Logged
