May 24, 2012, 10:47:08 PM *
Author Topic: air pressure question for 42's and beadlocks  (Read 399 times)
« on: March 23, 2011, 02:21:15 PM »
what should i run?
running kmc beadlocks and irok stiky 42's.  i currrenly have the rig sitting at 0 psi, but i think it might be too low.  i burped an inner bead while turning on hot dry pavement while pulling out of the shop.  this is why i ask.
anyone with experience?
« Reply #1 on: March 23, 2011, 02:38:22 PM »
i run around 3-4 or maybe 5 or 6 or so. i honestly don't have one set pressure i run at. i lower them till they are soft. oh and this was for both my 42" swampas and my 44" pitbulls
0 is way to low and you will blow inner beads pretty frequently if you run it that low (as you found out)
« Reply #2 on: March 23, 2011, 06:09:53 PM »
Cool thanks
makizoo
Baconator
« Reply #3 on: March 23, 2011, 07:21:22 PM »
I'd say as low as you can without losing inner beads.  My 37" PBR's on beadlocks won't go below 8 psi without blowing the inner bead. Angry
« Reply #4 on: March 24, 2011, 01:22:02 PM »
did you sell your irocks?
« Reply #5 on: March 24, 2011, 02:22:20 PM »
Dave07 has them
makizoo
Baconator
« Reply #6 on: March 24, 2011, 03:40:50 PM »
Sold my Iroks to Dave and bought Mark's Pitbull's.  More NEJ swapshack Grin
JP
« Reply #7 on: April 25, 2011, 04:35:27 PM »
When I had 36" and 38", the rear I took the valve stem out and when the air was done, I put the stem back in and 2-4lbs up front. But, I guess that also will depend on vehicle weight.
Common sense isn't so common
