May 24, 2012, 10:54:06 PM
bad vibes
Topic: bad vibes (Read 1820 times)
Switch
Do work.
bad vibes
August 06, 2007, 03:07:45 PM »
So I was getting some pretty bad vibrations in my jeep. The driver's wheel hub was trashed, and the pass is in OK shape. I replaced the driver's side hub, and also disconnected the front driveshaft. The vibes went away for the most part, but on my way to work this morning the jeep is making horrible sounds coming from the transfer case and it started vibrating my teeth out. I was going like 55 at the time. I stop, look under the car, and the housing to the transfer case is shattered and there's fluid covering everything. Did this happen because I had a LP 30 and the angle was off? For mods I have a 1" poly motor lift, 1" body lift, 2" budget boost and 33s. I also have a poly trans. mount. I can't think of why it would just shatter like that...
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
ayoung
Get Some
Re: bad vibes
August 06, 2007, 03:16:39 PM »
haha it would have been hilarious if you came on and said that you had a stock tranny mount and poly motor mounts
regardless, that sucks
Switch
Do work.
Re: bad vibes
August 06, 2007, 03:21:07 PM »
I did the motor mount and tranny mount in late april
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
ayoung
Get Some
Re: bad vibes
August 06, 2007, 03:35:54 PM »
tcase was probably just all sorts of jacked up and decided that was the appropriate time to sh!t the bed
Re: bad vibes
August 06, 2007, 04:09:24 PM »
Where exactly does the crack appear to start. I don't think your mods you listed would be the cullprit. Generally the Pinion U-joint would be the first thing to blow up, then the Tcase... and that is far more common in a rear application and not the front.
I tend to agree with Adam, You got junk. Didn't you drive around for like 3 weeks with just the front axle? and recently didn't you put in a SYE?
Switch
Do work.
Re: bad vibes
August 06, 2007, 04:31:59 PM »
Quote from: jps4jeep on August 06, 2007, 04:09:24 PM
No, that was RMTJ, not me. I don't have a sye yet. I havn't had time to really look at it yet as I'm still at work and in my work clothes, but the entire back is shattered.
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
ayoung
Get Some
Re: bad vibes
August 06, 2007, 04:34:36 PM »
possible lackage of said sye could help the kaboomage
Switch
Do work.
Re: bad vibes
August 06, 2007, 05:10:47 PM »
All the vibration seemed to be coming from the front end though. When I took off the front driveshaft, the vibration became significantly less.
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
Re: bad vibes
August 06, 2007, 10:28:41 PM »
This is alittle far fetch, but there is a possibility that your front output U joint went bad and maybe from the out of balance rotation broke something inside the t-case. It is particularly hard to diagnose with out seeing..
RMFJ78
Re: bad vibes
August 06, 2007, 11:24:54 PM »
yup that was me that ran in front wheel drive for about 2 weeks, had to do it again when i lost my rear driveshaft in boston traffic, that was fun, breaking on pavement. The sye solved all driveline vibes, i do have a steering wheel shake that wont go away even with proper tire balance (though they dont stay balanced long)
Switch
Do work.
Re: bad vibes
August 06, 2007, 11:39:13 PM »
what looks like what happened is the front shaft was pushed through the back of the case, shattering it completely. The belly pan was full of pieces of the case...woohoo
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
Re: bad vibes
August 07, 2007, 07:15:23 AM »
atleast a 231 is cheap
Look around a bit, I know i sold my last one with an sye in it for $150
Re: bad vibes
August 07, 2007, 07:51:27 AM »
Quote from: Switch on August 06, 2007, 11:39:13 PM
you should take pics.
RMFJ78
Re: bad vibes
Reply #13 on:
August 07, 2007, 08:05:54 AM »
Quote from: Twisty on August 07, 2007, 07:51:27 AM
x2
and if i can find a 231 for that cheap I might buy one as a spare, or maybe just save up for something stronger.
Switch
Do work.
Re: bad vibes
Reply #14 on:
August 07, 2007, 08:49:37 AM »
my camera can't take pictures at night, i tried last night but they all just came out too dark to see anything.
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
bad vibes
