May 24, 2012, 11:00:27 PM
Bent axle tube
Topic: Bent axle tube (Read 479 times)
Bent axle tube
April 30, 2011, 08:06:21 PM »
ok so as I have posted this before and am getting really tired of possing money , time and possibly safety away. I through the new axle out of my jeep AGAIN! After only 75miles. New axles, bearings, seals, plates etc etc.
Axles were assembled by Sunny Side Ford in Holden proffesionally by a mechanic.
And Yes Charles I did have the bearings packed as I am VeRY aware now that these are not lubricated by the differential fluid. These were installed in the housing properly.
Now my question is could I have bent my axle tube on the drivers side enough to be causing me to chew up the outer bearings?
It's all I can come up with. Other possible causes?
in the meantime I will be looking for a sold amc20 housing and installing my locker and axles into it. I will be doing the 4:88's at the same time I think. But I am just at awe with this bearing issue and that's all I can come up with.
Had to get towed home 52 miles from home in Newton and spent the better portion of my day hating my jeep. Any thoughts?
Re: Bent axle tube
April 30, 2011, 08:35:22 PM »
Give it to me!
Sucks about your luck, Rich.
Re: Bent axle tube
April 30, 2011, 08:38:30 PM »
did the axle go in hard? did it slide in like normal?
Re: Bent axle tube
April 30, 2011, 08:48:03 PM »
Sorry to hear. Did the bolts shear again? Were new races added with the bearings?
Bent tube, it’s possible, it will be something you will have to check. If it’s not obvious eyeballing it or using a straight edge on the tube you’ll need to be more precise. Remove the shafts and backing plates, use 2 straight edges horizontally at the ends of the tube. Take a measurement from 11” above and below the tube and across to each tube end, if there is .04” difference the axle is trash.
Another thought would be play at the race.
Last Edit: April 30, 2011, 08:51:18 PM by Posimoto
Re: Bent axle tube
April 30, 2011, 09:00:04 PM »
http://boston.craigslist.org/sob/pts/2350339027.html
Re: Bent axle tube
April 30, 2011, 11:32:26 PM »
I boughttimken bearings and seals and they were 1 piece sealed units and the mechanic used a bearing greaser to press the grease in good Posi
Everything slid in fairly smooth Bob.
I can see this happening once but this is rediculous. Emailed that guy in Raynam Bob and I plan to go grab that set of axles tomorrow if he still has them.
thanks. 2:71 gearing ? great even higher geared tha my 2:73's
2:71"s lol they might be 4:10's obviously he cant count teeth and do math
Re: Bent axle tube
May 01, 2011, 12:47:06 AM »
I once had a bent axle housing that came part nice, it was only noticable when we re assembled it..good luck d.
Last Edit: May 01, 2011, 01:00:23 AM by jerry k
JP
Re: Bent axle tube
May 01, 2011, 02:01:20 AM »
My opinion, scarp it and get a better rear axle. 20's have a strong R&P, but when it comes to those tubes between bending and twisting, not worth the aggravation. 44, 8.8, 60? Something else.
Common sense isn't so common
Re: Bent axle tube
May 01, 2011, 07:47:40 AM »
Quote from: BiGdAdDeE on April 30, 2011, 11:32:26 PM
thanks.
I'm sure they are 2:73s. I'll be at the sawmill w/Dave if you want to swing by.
rich
Re: Bent axle tube
May 01, 2011, 08:50:43 AM »
Big d swing by my house I will give you a amc 20 for free you just have to remove it (easy there is no bodyy on the jeep and I have tools to do it
79cj5
66cj5 134,t90
66cj5 225 dauntless
47 bantam tc3
Re: Bent axle tube
May 01, 2011, 09:34:26 AM »
Quote from: rich on May 01, 2011, 08:50:43 AM
do you still have my seats at your house
If I am going to Weymouth I will gladly take that home too
Bent axle tube
