« on: July 18, 2010, 08:34:06 AM » |
So we wheeled the aptly named Carnage saturday. I tore my rear brake line off, blew the rear driveshaft breaking a bolt off in the yoke, had a spare shaft, couldn't use it. I think I blew the front pinion gear. So I could not move under my own power, and could barely stop. thanks to Jerry for dragging me back to camp. I need a new hobby?
« Last Edit: July 18, 2010, 08:58:05 AM by Axle »
« Reply #1 on: July 18, 2010, 08:57:04 AM » |
Sorry to hear Bob,
Your rear axle has been hammered the last few outings.
« Reply #2 on: July 18, 2010, 08:58:24 AM » |
sorry, front pinion gear.
« Reply #3 on: July 18, 2010, 09:05:32 AM » |
Bob, ever since you found the gas pedal last year your jeep has paid for it. Was that 2 years ago?
« Reply #4 on: July 18, 2010, 09:11:47 AM » |
I've been wheeling the jeep for 6 years, I think the 36s did me in.
« Reply #5 on: July 18, 2010, 09:32:13 AM » |
wow bob, your hard core now!
better start on the one tons.
'00 tj (see above) '95 Cherokee '82 Cherokee '83 wagoneer (rusted out parts vehicle
« Reply #6 on: July 18, 2010, 09:46:43 AM » |
Your time has come I guess. You wheeled and broke the like the last 3 events consecutively. I say go one tons and sell me the front chromolly shafts to help pay for the build. Your ready for the change.
98 ZJ in progress DD 90 K5 Kubota
« Reply #7 on: July 18, 2010, 09:50:01 AM » |
damn, sounds like that place earned the name carnage.
« Reply #8 on: July 18, 2010, 10:39:21 AM » |
Upgrade to Dana60's with 1410 shafts and youll NEVER brake. Brake lines well its one of those things you cant really upgrade, just cary spares, they take very little room.
« Reply #9 on: July 18, 2010, 03:29:23 PM » |
update; I took the cover off and,..    so at this point all I need is an open carrier. I will still take a chevy 60 though.
brooksy
« Reply #10 on: July 18, 2010, 03:42:34 PM » |
I'm sorry Bob. You never brake while I am there. I guess I need to fix my junk and get on the trail.
Did you shear the cross shaft and that caused damage to the carrier? That seams impressive to me. anyone else seen this type of breakage?
99 TJ 68 M715
« Reply #11 on: July 18, 2010, 03:45:55 PM » |
Nice work! don't often see that.
Did you test the x-shaft hardness when installing the lock-rite?
« Reply #12 on: July 18, 2010, 03:50:39 PM » |
guess its time to get everything cryo treated
« Reply #13 on: July 18, 2010, 05:57:23 PM » |
I don't know what broke first, the shaft or the carrier? but it was a stock one, not a hardened one.
ayoung
« Reply #14 on: July 18, 2010, 07:59:36 PM » |
i think Bobby is referring to how the lockrite instructions tells you to score your stock cross shaft with a file and if it makes a mark you have to buy another one because the one you have wont stand up to the abuse of the locker. i maybe wrong as i did this 4 or 5 years ago, but i remember having to get a new cross shaft because i was worried about mine as it made a small score when i used the file on it and i was rebuilding my entire front end due to a previous bone head move so i didnt want it to get trashed again. that being said, almost everyone i have known has run the stock cross shaft and not had problems.
