May 24, 2012, 11:06:48 PM
brake bleeding kit
Topic: brake bleeding kit (Read 286 times)
brake bleeding kit
November 11, 2011, 07:39:28 PM »
I would like to Finlay buy a brake bleeding kit, so I can bleed by myself, and get all the air out.
anyone have any recommendations?
Re: brake bleeding kit
November 11, 2011, 09:12:06 PM »
I've had good luck with Mityvac.
November 11, 2011, 11:08:20 PM »
Most all will do a good job. I bought an inexpensive one (below) and it has worked fine for a number of years. You can use the pump for many different diagnostic jobs as well.
http://www.autozone.com/autozone/accessories/OEM-Liquid-siphoning-vacuum-pump-kit/_/N-25j2;jsessionid=480F573FAE4C9432AE61BB0852EE87DC.diyprod3-b2c5?counter=1&itemIdentifier=70116_0_0_
November 12, 2011, 08:14:06 AM »
thanks guys!
Technohead
Old School
November 13, 2011, 01:51:26 PM »
I bought one from Sears that is almost identical to mityvac except it came with a case. It fell apart the first time I used it.
-Eric '96 ZJ
November 13, 2011, 02:16:10 PM »
I held off and did the pump 'em hold 'em 2 person method.
ayoung
Get Some
November 13, 2011, 06:30:15 PM »
Quote from: Axle on November 13, 2011, 02:16:10 PM
that's always worked for me
November 13, 2011, 07:14:00 PM »
You can also take a long hose, and put it in a jar of fluid with the end submerged, and pump by yourself. Since it doesn't see air it will not suck air back in.
rafikie
November 14, 2011, 03:11:07 PM »
I'm a fan of speed bleeders. The bleed screws have a check valve in them so all you do is crack them loose, run a line to a catch pan and pump away. Keep an eye on the fluid, tighten the screw back up and move to the next one.
Jeremy
Western Mass 4x4
brake bleeding kit
