May 24, 2012, 11:09:19 PM *
Author Topic: Carb issue  (Read 176 times)
BlackWhyJay
« on: October 21, 2011, 03:37:46 AM »
This question was asked of me and since I'm not sure of the answer, I'm asking you guys...
"After my CJ5 runs for a few minutes, it stalls out and I find gas leaking out of the bottom of the carburetor. I think the float valve is sticking. Any easy remedy for that, or am I forced into rebuilding the carb?"
Thank you all in advance.
« Reply #1 on: October 21, 2011, 08:21:10 AM »
Including the year CJ5, engine, and carburetor in your question would help us to better answer your question.
The CJ5 was fitted with several different Carter carbs, on the (F-134), (232), (258), engines, also the Rochester, (225) and MC2100, (304).
[/quote
There is a good chance the synthetic tipped needle is dirty and isn't seating. Outside chance there could be a crack in the carb but it’s not typical.
If it’s the needle the easiest remedy would be to tap the side of the float bowl with the handle end of a screwdriver. However, I would only do this to verify the needle wasn't seating. I would suggest removing the air horn (4 screws) take a good look to make sure nothing is amiss then spry some carb cleaner on the needle and seat assembly.
I hope this helps.
« Last Edit: October 21, 2011, 08:47:07 AM by Posimoto » Logged
