May 24, 2012, 11:38:02 PM
Dana 60 flush hubs?
Topic: Dana 60 flush hubs? (Read 405 times)
Dana 60 flush hubs?
July 22, 2010, 10:28:46 AM »
does anyone know if there is someone out there that makes an almost flush hub(non selectable) for a front Dana 60? I know they make drive flages, anyone who has the drive flanges, could you possibly measure for me the distance from the wheel mount surface to the end of the flange?
essentially I am looking to have that be as little as possible
I could run the drive flange and a wheel spacer BUT I currently have 5 x5.5 pattern so It will make the spacer a little thin between bolt holes and ID.
Re: Dana 60 flush hubs?
July 22, 2010, 12:02:51 PM »
I don't have mine to measure, but my best guess would be less than a 1/4 inch off the end of the hub. I will measure when I get home if no one else responds
July 22, 2010, 12:08:54 PM »
x2, drive flanges only stick out .25"-.375" past the hub.
July 22, 2010, 12:52:32 PM »
who makes shorter hubs? I bet they are $$
July 22, 2010, 12:53:20 PM »
dynatrac make super shorty hubs i believe
July 22, 2010, 02:12:48 PM »
July 22, 2010, 02:13:51 PM »
if your running slugs, I guess you could cut the hub down, the flange down and teh shaft, but you are limiting and minimizing your spline engagement
July 22, 2010, 02:25:21 PM »
just limit your backspacing if your looking to protect your hub from rock contact.
you can check out and measure my flanges when you pick up your steel.
jon
July 22, 2010, 03:13:26 PM »
unit bearing knuckle/hubs are your best bet.
July 22, 2010, 04:44:38 PM »
wasn't looking for the thickness of the flanges looking for the distance from wheel mount to end of mounted flange.
don't care about protecting th hubs. actually just trying to run a certain wheel but it's looking like I may have to do a bit to much for mods to run it.
And I think what Jon has suggested is the only option to allow what I want to do.
Last Edit: July 22, 2010, 04:45:18 PM by HEYzipupyourfly
July 24, 2010, 09:03:36 AM »
Hey Tony you know some of the members kids can on occasion read this forum, you think your avatar is appropriate?
July 24, 2010, 09:54:36 AM »
ah yes....
problem taken care of
Dana 60 flush hubs?
