May 24, 2012, 11:44:58 PM *
Author Topic: disk brake conversion  (Read 665 times)
garageRatt13
« on: August 15, 2011, 10:46:48 PM »
Hey guys do you know of any disk brake conversion kits for the rear axle on my xj? Or of an disks that fit that i could grab from a junkyard?
1998 Jeep Cherokee Limited - 4.5in. Rubicon Express and 33 12.50 BFG KM2s.
1975 Datsun 280Z - chevy 350 with some other mods..
1973 Honda CB450 - stock
« Reply #1 on: August 16, 2011, 12:52:17 AM »
It's probably not worth putting any money into your rear axle.
garageRatt13
« Reply #2 on: August 16, 2011, 04:41:05 AM »
What do you suggest then?
« Reply #3 on: August 16, 2011, 06:22:57 AM »
if it is for the 8.25 then i have no help. i know of no other factory disc brake kits that will swap over
now a d44 that is easy many kits are avalible to run disk brakes. buying a 8.8 from a explorer will get you disk brakes and better gearing than you have now i bet and prob would cost the same as a disc brake kit for the 8.25
garageRatt13
« Reply #4 on: August 16, 2011, 08:00:30 AM »
will the 8.8 bolt in? what needs to be changed to make it fit?
« Reply #5 on: August 16, 2011, 08:05:03 AM »
this is a swap that is pretty popular and there is a ton of info out there on the web.
if the gears are the same you probably just need to move the spring perches.
« Reply #6 on: August 16, 2011, 08:05:27 AM »
No kit I know of, I am sure you piece something togethef, but like mention, in the end may not be worth it.
If you hell bent on it, I'd start with a dodge intrepid rear rotor, I recall doing a brake job on one and it was a 5_4.5 bolt pattern, and appeared to have plenty of offset to allow for a caliper mount to be welded cleanly to tge tube. For calipers, I run 84 eldorado rear's, toranado's and riviera's of the same vintage should also be the same. The mount will be made of 1/4" plate, make templets out of cardboard and plan on making a bunch. When I made mine, I made 2 mounts before I had one that worked properly, fit the caliper and allowed for proper placement and movement.
« Reply #7 on: August 16, 2011, 09:02:14 AM »
Pretty sure you can source parts from a ZJ with a dana 35. You should be able to part this together for under $100
« Reply #8 on: August 16, 2011, 09:04:07 AM »
http://www.madxj.com/MADXJ/technical/technicalfiles/BAzjRearDiscsOnXJ/ZJrearDiscsOnXJ.htm
http://jeep.blackonyx.net/pdfs/zjreardiscs.pdf
X-BoB-J
J33P
« Reply #9 on: August 16, 2011, 10:42:36 AM »
The liberty swap is easier IIRC
 http://www.jeepforum.com/forum/f11/fitting-kj-liberty-rear-disc-brakes-xj-cherokee-8-25-axle-750112/
« Reply #10 on: August 16, 2011, 10:49:42 AM »
do you know what your rear axle is?
X-BoB-J
J33P
« Reply #11 on: August 16, 2011, 10:51:46 AM »
if its 98 w/o ABS chrysler 29 8.25. If he has abs, dana 35.
garageRatt13
« Reply #12 on: August 16, 2011, 07:20:15 PM »
im pretty sure it has abs since it has it up front so im guessing a D35.
« Reply #13 on: August 16, 2011, 07:31:53 PM »
Some vehicles are abs only in the front or rear, not sure about jeeps. Look for a tone ring on the axle shaft or a sensor back there.
Tone ring looks like:
It will be located here:
« Reply #14 on: August 16, 2011, 07:48:37 PM »
I believe the dana 35 has a rubber fill plug, usually leaky.
