May 24, 2012, 11:52:18 PM *
Author Topic: dually question  (Read 194 times)
« on: July 26, 2010, 06:54:57 PM »
basically this pertains to a 94-02 dodge, exactly what is entailed in converting a DRW to a SRW?
I assume swap the bed
take off the rear wheels and dully hub
is the front still use a unit bearing? I have not worked with a dodge dually front axle? can it be turned down? should I just swap out for a free wheeling hub conversion?
wondering thanks.
jason m
« Reply #1 on: July 27, 2010, 07:37:28 AM »
Never done it, but I think the front use's the same SRW as the DRW, just with a spacer for the DRW hub. So if that true then its a no brainer, if not its probally just a unit bearing swap from DRW to SRW.
The rear dana 70 ( or 80 ) it may not need a hub swap. Most Dodge 70's ive seen are wide and are not like a 14 bolt were they used the same housing with two different hub like the SRW and C&C. So that might be as easy as swapping the bud hub rims for single's.
Jason.
« Reply #2 on: July 27, 2010, 07:44:37 AM »
Thanks, kinda what I was thinking, I just have not tinkered a whole lot with dodge dually axles. I am seeing a lot of 3500 cummins duallys with less miles selling for considerably less than 2500 (or comprable) with all these bells and whistles. But I do not want a dually.
jason m
« Reply #3 on: July 27, 2010, 07:53:10 AM »
The Cummins will have the 80, so if you search for this search for the 80 conversion.
Jason.
« Reply #4 on: July 27, 2010, 02:22:44 PM »
roger that, all cummins have 80's or just the 3500 cummins?
F-it, I'll google.
