May 24, 2012, 11:58:05 PM
engine coolant
Topic: engine coolant (Read 951 times)
engine coolant
May 12, 2011, 08:21:28 PM »
Any one ever run dihydrogen monixide in their cooling systems? I've heard this stuff works pretty well, and is easy to find. Mix it with a little Prestone, and it will keep your engine cool. Or so they say.
Any input?
Re: engine coolant
May 12, 2011, 08:25:25 PM »
my cj never goes over 185..but i'm curious about this chemical that speak of. do you have overheating issues or just running too hot on the trail ?
Re: engine coolant
May 12, 2011, 09:26:47 PM »
I run it in mine, 50% mix with prestone. Works great.
P.S. - What made you feel so crafty tonight
Last Edit: May 12, 2011, 09:27:18 PM by Bluerocket
Re: engine coolant
May 12, 2011, 09:46:29 PM »
I lost some coolant when I disconnected a radiator hose so I could drill out a broken bolt. Thinking of replacing it with this stuff.
Glad to hear it works. I think I'll run it.
Re: engine coolant
May 12, 2011, 10:11:45 PM »
where do you get it?
Re: engine coolant
May 12, 2011, 10:56:27 PM »
It's usually quite dangerous.
Almost like snakes on a plane
http://www.youtube.com/v/vLaX8UvVUQw&rel=1
Re: engine coolant
May 13, 2011, 05:44:36 AM »
Quote from: Axle on May 12, 2011, 10:11:45 PM
It's actually quite common. You can get it just about anywhere.
Re: engine coolant
May 13, 2011, 05:53:39 AM »
i dont understand why you dont just use antifreeze? what is the boiling point of this hydrogen peroxide mix?is it corrosive? again. why try to be different with anything as simple as coolant?I can see trying to find the non-toxic antifreeze since we commonly dump it on the earth while wheeling but other than that i'm confused.
mattamd_xp
Re: engine coolant
May 13, 2011, 06:52:30 AM »
Quote from: HEYzipupyourfly on May 13, 2011, 05:53:39 AM
You have to use antifreeze with this dihydrogen monoxide. I use it in all of my vehicles and it works wonders and is 100% bio friendly
Re: engine coolant
May 13, 2011, 07:48:59 AM »
Athletes use the same stuff to enhance their performance.
Re: engine coolant
May 13, 2011, 05:50:18 PM »
Unless there was a clear overheating issue, why bother. Efi motors are not like carbed motors where the colder they run the better. For the benefits of running cooler was neede, there are other specific peramiters that would need to be addressed as well (re map perhaps).
I assume the point of this stuff is to change the energy of activation to convert water to gas (raise boiling temp) with regular anti freeze/water mix, you wern't having issue, why bother water is stabile to I think 230 with a conventional 50% mix.
Edit, if the point of this stuff is to change the thermal conductive properties of water, then maybe, but water.s thermal conductivity is .058 milli-volts, I would see what the stuff claims.
Last Edit: May 13, 2011, 05:53:09 PM by jps4jeep
mattamd_xp
Re: engine coolant
May 13, 2011, 05:59:39 PM »
Quote from: jps4jeep on May 13, 2011, 05:50:18 PM
Edit, if the point of this stuff is to change the thermal conductive properties of water, then maybe I would see what the stuff claims.
You should google it to see what its claims are
Re: engine coolant
May 13, 2011, 10:43:04 PM »
I picked some up today. The stuff is 100% biodegradable. It's so awesome, you can even drink it (like Chuck said). I think everyone should use it in their cooling systems!!
Re: engine coolant
Reply #13 on:
May 14, 2011, 07:29:19 AM »
Re: engine coolant
Reply #14 on:
May 15, 2011, 08:35:58 AM »
Put some in my cj-5 and cj-7 this AM, splendid.
engine coolant
