kev711
« on: June 23, 2011, 03:22:02 PM » |
I have a 98 tj with a 2.5L with about 107,000 miles. I give her full synthetic oil changes about every 5,000 miles or so. Doesn't leak a drop of oil and never had a problem. Today i hear a knocking from the engine and it gets faster as i hit the gas and she's burning oil and blowing white smoke from the exhaust. Blown ring? cracked piston? is there any hope left for my engine? any advice? thanks
« Reply #1 on: June 23, 2011, 03:33:59 PM » |
white means coolant, did it overheat?
pianoguy
« Reply #2 on: June 23, 2011, 03:46:31 PM » |
I have never heard good things about Synthetic oils they really are not good for seals. Sounds like a head gasket and a stuck rod.
« Reply #3 on: June 23, 2011, 04:22:56 PM » |
Do a compression test.
Nothing wrong with synthetic oil
Switching to synthetic on a high mileage engine is said to cause seal leaks
« Last Edit: June 23, 2011, 04:27:25 PM by Posimoto »
kev711
« Reply #4 on: June 23, 2011, 05:00:23 PM » |
didn't over heat...yet. and since it has 107,000 on the ticker, looks like i should go to regular oil then. the smoke is white but it smells like it's burning oil though
« Reply #5 on: June 23, 2011, 05:12:56 PM » |
check engine light on?
« Reply #6 on: June 23, 2011, 05:45:28 PM » |
white smoke is coolant, you blew a head gaskey is my guess?
is there coolant in the oil?
check compression as chuck said
do you have goo doil pressure? any oil pressure?
how do you know its using oil? did you check it fill it and check again after driving and it was low?
« Reply #7 on: June 23, 2011, 05:50:15 PM » |
X2 compression test check oil for coolant check coolant for oil check oil pressure when running
navman 5.0
« Reply #8 on: June 24, 2011, 11:34:00 AM » |
How does the exhaust smell? Should be able to tell the diff between the 2. Coolant has a bit of an odd sweet smell while oil smells like a fresh paved road. Best analogy I could think of lol
kev711
« Reply #9 on: June 24, 2011, 02:54:31 PM » |
great job on the analogy..lol exhaust doesn't smell sweet at all but can't really tell about the paved road smell. gave her an oil change about 3 weeks ago and the oil still looks new and the antifreeze looks great too. gotta get that compression test done. gotta get a gauge and never done one...gotta youtube it
« Reply #10 on: June 24, 2011, 05:33:11 PM » |
You should be able to rent one from the parts stores, general idea is you pull a plug and bolt it in then crank the engine. Then repeat that for each cyl. At least thats how I've done it in the past. I think I pulled the wire to fuel or coil so it would not fire as well.
kev711
« Reply #11 on: July 16, 2011, 02:14:59 PM » |
i have compression but a mechanic friend of mine said it might be a rod. anyone familiar with the 2.5 willing to come take a quick look to see if i can still save my engine before i start looking for another 2.5 to swap in? if you willing to take a drive out to lend a hand, i'd cover your gas. any help at all would be really appreciated. it's my daily driver, so thank god i live close to work
« Reply #12 on: July 16, 2011, 02:39:35 PM » |
where do you live?
kev711
« Reply #13 on: July 16, 2011, 02:57:38 PM » |
north end of bridgeport
« Reply #14 on: July 16, 2011, 03:18:48 PM » |
1hr 50mins, ouch. sorry.
