« on: August 06, 2011, 11:33:51 PM » |
what does everyone have and where did you get it? i would like to have a seat in the back of my jeep eventually so that smaller the better....thanks guys
« Reply #2 on: August 07, 2011, 08:01:32 AM » |
I got mine from summit for $34 shipped I believe sold it right afterwards for 200.00  I watch summit like a hawk now
98 ZJ in progress DD 90 K5 Kubota
« Reply #3 on: August 07, 2011, 08:15:02 AM » |
I have an RCA cell in my cj, which I believe fits behind the stock seat if you wanted that. I got it beacuse its wide/tall rather than taking up a lot of the cargo space.
mopar_power
« Reply #4 on: August 07, 2011, 08:26:28 AM » |
RCI 2161A off Ebay i did the same thing. it fits right behind the back seat.
05 tj juggy
« Reply #5 on: August 07, 2011, 09:18:30 AM » |
cool thanks guys. are you running an external pump with these? if so, which one?
mopar_power
« Reply #6 on: August 07, 2011, 09:23:20 AM » |
i have the factory pump with the genrite ring
05 tj juggy
« Reply #7 on: August 07, 2011, 02:55:09 PM » |
I run an external pump which came with my TBI kit for the 360. (which finally mostly works now!).
« Reply #8 on: August 07, 2011, 06:15:54 PM » |
can I use the same cell for a carb'd jeep? my guess is yes.
« Reply #9 on: August 07, 2011, 07:01:22 PM » |
I run the same one that these guys are talking about. Shelton runs his in the tank and has the yj pump
'00 tj (see above) '95 Cherokee '82 Cherokee '83 wagoneer (rusted out parts vehicle
« Reply #10 on: August 07, 2011, 09:20:24 PM » |
cool thanks, i thought that was what you and shelton ran too. i think i will grab one of them! thanks guys!
« Reply #11 on: August 07, 2011, 09:54:43 PM » |
So long as your mechanical pump can pull the fuel up and out of the tank it'll work fine. Mine has 3 holes, fuel pickup fuel return and vent. You'd just plug return. *note you do need to get some funky AN fittings to adapt the tank to a standard fuel line. I did a size adapter and then a 90 deg barb or so.
« Reply #12 on: August 08, 2011, 07:34:42 AM » |
*note you do need to get some funky AN fittings to adapt the tank to a standard fuel line. I did a size adapter and then a 90 deg barb or so. call tim to help out with the -AN fittings
fixed it for ya
jon
« Reply #13 on: August 08, 2011, 08:44:11 AM » |
So long as your mechanical pump can pull the fuel up and out of the tank it'll work fine. Mine has 3 holes, fuel pickup fuel return and vent. You'd just plug return. *note you do need to get some funky AN fittings to adapt the tank to a standard fuel line. I did a size adapter and then a 90 deg barb or so. Having the tank higher will help the pump as once it primes the line most of the work will be siphoning. you can get aluminum AN fittings but JIC stuff will work as well AN-6 = JIC-6 they are dimensionally interchangeable.
« Reply #14 on: August 08, 2011, 08:46:44 AM » |
what is the difference between AN and JIC?
