May 25, 2012, 12:27:31 AM
How much does a ford 8.8 weigh?
Topic: How much does a ford 8.8 weigh? (Read 1476 times)
Casey L
August 13, 2007, 04:09:44 PM »
I think I am going to try and get one at Hollands $50 grab day. Anyone know?
Also, how much does a 44 Aluminum out of a ZJ weigh?
03 Rubicon - Stock w/ 32's
Re: How much does a ford 8.8 weigh?
August 13, 2007, 04:12:37 PM »
Depends if you still have the brakes on the axle... probably close to 200lbs with the brakes and all.
you can cut the weight down to about 150 if you pull the calipers and rotors and drain all the gear oil out.
No clue what a Zj 44 weighs, probably about the same as a pile of doo doo...
August 13, 2007, 04:27:53 PM »
Casey, whens this $50 grab day? I might try to get some new axles out of there if they are $50 each.
August 13, 2007, 04:31:24 PM »
you want an 8.8. not a d44a
Casey L
August 13, 2007, 05:15:35 PM »
Its august 25th!!! Don't miss out on the action!
Could this be me?
The only problem is that I broke my back 2 years ago (screwed up T-12). So I don't want to mess myself up too bad.
August 13, 2007, 06:00:09 PM »
Casey, I can try to go to that, to give you a hand. I want to get new axles for the MJ...are ALL axles $50?
Last Edit: August 13, 2007, 06:00:36 PM by Twisty
August 13, 2007, 09:56:55 PM »
Yup... thats hollands
Casey L
August 13, 2007, 11:32:46 PM »
Anything you can carry $50
Switch
Do work.
August 13, 2007, 11:48:19 PM »
oOooo I want to come!
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
ayoung
Get Some
August 14, 2007, 09:12:59 AM »
Quote from: Twisty on August 13, 2007, 06:00:09 PM
why do you want new axles for the mj
and in my opinion, if you can carry the axle, it probably isnt beefy enough to bother swapping into your jeep
August 14, 2007, 09:50:38 AM »
Quote from: ayoung on August 14, 2007, 09:12:59 AM
I think you need to do more shrugs then.. get back in the gym!
August 14, 2007, 10:45:21 AM »
Because I didnt feel that confident with the D30...and if they were $50 each, I figured that I would get some beefier axles to build over the next year or two. But I had some rather large axles in mind...and I know that 1 person would NEVER be able to carry them.
Casey L
August 14, 2007, 12:03:34 PM »
Tim lets get some axles out of a semi truck and put them under the MJ!!! lol.
Also I posted the grab day in the public events section so more people can come.
Reply #13 on:
August 14, 2007, 12:30:19 PM »
Quote from: Casey L on August 14, 2007, 12:03:34 PM
rockwells!
Reply #14 on:
August 14, 2007, 02:05:40 PM »
There is a set of rockwells on craigs list NH for $900. Its tempting, but a little too overkill now. if ALL axles were $50 i was going to try to find a 14bolt and a D60 out of a chevy. Not bad for $100, and build them slowly over the next year or so. But a fully dressed D60 comes close to 400lbs...so its not a one person deal.
