Casey L
« on: August 05, 2007, 12:51:14 AM » |
I realized today that my transmission mount is like throwing a hot dog down a hallway, as well as my motormounts, but I already knew that. My car makes this nasty clunk sound going from reverse to drive.
What do you guys recomend? The more ones or should I just get NAPA cheapo's. I have access to an engine lift for this month so it should be easy to do.
03 Rubicon - Stock w/ 32's
« Reply #1 on: August 05, 2007, 01:50:50 AM » |
MORE bombproof motor mounts. poly tranny mount?
« Reply #2 on: August 05, 2007, 08:28:39 AM » |
x2
ayoung
« Reply #3 on: August 05, 2007, 10:05:31 AM » |
you dont need an engine lift, just a floor jack...takes about 30 minutes (at least in a 94 xj)
Casey L
« Reply #4 on: August 05, 2007, 02:25:47 PM » |
Yeah I know I don't need one, but I think it will make the job a lot easier.
Plus, my floorjack sucks, I have to stack like 8 inches of wood on top of it to actually lift my jeep up!
Where is a good place to buy the more engine mounts?
X-BoB-J
J33P
« Reply #5 on: August 05, 2007, 05:32:22 PM » |
i got a set of them MORE ones, i love them, there holding up great also look way more beeefy than stock
Liza
« Reply #6 on: August 05, 2007, 08:41:46 PM » |
You can get them direct from M.O.R.E http://www.mountainoffroad.com/more.htmBay State Off Road is also a dealer, so I can get them for you too!
Casey L
« Reply #7 on: August 05, 2007, 09:05:54 PM » |
I don't think they make one specifically for a ZJ, I wonder if the XJ one will work. Maybe I will call them.
Liza
« Reply #8 on: August 06, 2007, 08:07:44 AM » |
Sorry, I missed you have a ZJ.
« Reply #9 on: August 06, 2007, 09:56:35 AM » |
If you use a poly mount for the engine, also use one for the transmission. also the poly mounts will transfer way more vibrations from the drive train to the chassis.
« Reply #10 on: August 06, 2007, 10:23:37 AM » |
the MORE mounts are not poly, they are actually rubber.
ayoung
« Reply #11 on: August 06, 2007, 10:28:09 AM » |
x2 have them in my jeep with stock tranny mount, they are awesome, no real extra vibrations and i have a stock tranny mount
« Reply #12 on: August 06, 2007, 12:04:51 PM » |
OK... the point was regardless of what you put in, make sure they are both the same..
Polyurethane and Bonded rubber have allowences for different amounts of flex, if you have one of each, due to engine rotation movement fore and aft of the mounts, you will prematurely tear/wear the mounts.
Poly mounts transfer more vibration over factory levels but are not nearly as harsh as a solid mount drivetrain.
« Reply #13 on: August 06, 2007, 01:24:05 PM » |
I ran the MORE mounts with a stock tranny mount, and then with a solid (welded) transmission mount. Never had any trouble with things snapping like you hear about in racing. I've always been told run all the same type, but i could not find a poly transmission mount for the xj.
« Reply #14 on: August 06, 2007, 01:31:29 PM » |
everybody knows that you can't run dissimilar mounts on a jeep. it will tear it apart
