May 25, 2012, 01:34:26 AM *
Author Topic: running like crap  (Read 1234 times)
« on: July 18, 2007, 09:16:46 PM »
hey guys
i have an 87 4 runna with a 22re motor, it was sputtering and hesitating. I thought it was the exhaust leak. I put in in new donut gaskets. I then threw plugs, wires, cap, rotor, fuel filter at it to make sure those weren't an issue either. i took it for a ride and didn't seem any better. when i got it back to the shop i saw the CAT was glowing red! I then figured it was the cat, so i replaced it.
It is NO Better at all and the new cat is glowing too!
What should i look at next??The muffler is recent too.
 I feel like it is dragging a boat anchor and sputtering still!!
Please help, any one ever run into this???
Jay
makizoo
Baconator
« Reply #1 on: July 18, 2007, 09:22:11 PM »
banana in th tailpipe?
« Reply #2 on: July 18, 2007, 09:23:49 PM »
I ain't fallin' for no banana in the tail pipe!
 Jay i don't know.
« Reply #3 on: July 18, 2007, 09:27:57 PM »
i looked .... no banana!!  It also was not the stickers i just finished!!!
 Any Real Input??? please??
Casey L
« Reply #4 on: July 18, 2007, 09:34:41 PM »
I think when the cat is red that means it is running rich. Did you try an o2 sensor, plugs and wires. Maybe clean out the MAF?
Sounds like an o2 sensor or a broken MAF.
On a side note, my friend is building up a turbo 22re and it looks sweet!!!!
03 Rubicon - Stock w/ 32's
« Reply #5 on: July 18, 2007, 10:02:00 PM »
Sorry Jay! lol Casey sounds about right.
« Reply #6 on: July 18, 2007, 11:02:01 PM »
that does sound possible, thanks casey.
i am gonna try diagnostic codes and see if it tells me anything.
any other suggestions welcome as this is car 2 and the heep need work too!! (typical)
thanks guys
« Reply #7 on: July 18, 2007, 11:17:32 PM »
I'm not sure if you will get codes from a 1987.  I know OBD-II came into existance in 1996...thats on Jeeps, not sure about Toyotas though.
Good luck Jay  Smiley
« Reply #8 on: July 18, 2007, 11:40:06 PM »
thanks tim
this does have a midevil diagnostic check so,
i jumped the diagnostic code box and it is reading 5 flashes, O2 sensor.
does this make sense??
it really runs like a$$
i just don't want to keep throwing parts at it but, it does read o2.
jay
« Reply #9 on: July 18, 2007, 11:44:07 PM »
o2 sensor controlls the richness of the air/fuel ratio.  if its bad, then the motor is running REALLY rich.
at carnage, my MJ had an o2 sensor with the wires cut off, and it ran fine.  do what casey suggested and try the o2 sensor.
can you get one from a JY?  getting a new o2 sensor for $80 and then findint out its not the part would reallly suck!
« Reply #10 on: July 18, 2007, 11:51:25 PM »
you are correct, that would suck to get a new one and not have it be it.
i looked up the diagnostic codes though, that is what the truck (and others) have told me.
the YJ o2 sensor is way different than this (of course)
i'll see in the morning what the deal is
thanks for the input guys
i'll keep ya posted.
jay
J.T. Woody
God is great, beer is good, & people are CRAZY
« Reply #11 on: July 19, 2007, 08:59:38 AM »
Twisty said JY (junkyard), not YJ.  Grin
Just to make sure there is no restriction in the exhaust, disconnect it after the cat and run it.  It is possible something got stuck down inside the muffler (if the old cat did go bad).
'84 Oldsmobile: Delta 88. 4-door battlewagon, driven daily
'04 Grand Cherokee: 2"BB/ Bilsteins & 245/75/16s. Wife's pavement pounder.
'90 Grand Wagoneer: Sold Sad
ayoung
Get Some
« Reply #12 on: July 19, 2007, 09:03:45 AM »
i agree with woody on the plugged muffler possibility, my old cat went bad and the entire guts ended up inside the flowmaster and had it almost totally clogged.  but if the truck is telling you the O2 sensor is bad, i would start there.
« Reply #13 on: July 19, 2007, 10:17:25 AM »
JY ha ha ha  i was thinking YJ that's funny!!!
I did try to disconnect it at the cat w/o the muffler,
it did not run any better.
ayoung
Get Some
« Reply #14 on: July 19, 2007, 10:18:36 AM »
i would def look into a new o2 sensor
