May 25, 2012, 01:42:23 AM *
Author Topic: Spring hitting track bar mount  (Read 193 times)
fubar25
« on: June 20, 2011, 08:28:25 PM »
I bought a 95 zj with a 4" lift.  I hear a rubbing noise when driving around.  I notice it is hitting the drivers side track bar mount.  I bought a Single Adjustable track bar to center the axle.  It is still doing this and the bar is maxed out.  (tie rod all the way in). The noise is not as bad but it is still there.  Any ideas?
thanks in advance
claudio
« Reply #1 on: June 20, 2011, 08:49:06 PM »
picture?
derickw
« Reply #2 on: June 20, 2011, 10:04:24 PM »
picture?
2X
how is the pinion and caster, adjustable control arms?
jeeptech
« Reply #3 on: June 23, 2011, 09:25:12 PM »
Is the axle centered in the body?   Who's springs are they?  Are the shocks the correct length for the spring height?  Is the track bar bracket bent?
Technohead
Old School
« Reply #4 on: June 24, 2011, 07:57:27 AM »
Spring is probably a little bigger diameter than stock. Mine does the same thing. Turn up the stereo and drive it.
-Eric  '96 ZJ
