January 16, 2018, 10:00:27 PM
Author Topic: Throwout bearing tech question  (Read 386 times)
Offline Corey G.
« on: March 23, 2015, 07:48:04 PM »
I have two brand new throwout bearings for my Jeep (one Luk and one Sachs). On both of them, the sleeve is not perfectly centered on the bearing. If I lay the bearing side down and keep it it one place, and look down through the sleeve while I spin it, the diameter of the sleeve is not centered with the bearing itself. The Luk is off about 1mm, and the Sachs is about 2-3mm off.
Did I get two crappy throwout bearings or is this normal?
2006 LJ
Re: Throwout bearing tech question
« Reply #1 on: March 23, 2015, 08:01:09 PM »
The Timken one I put in my F350 was not perfectly centered either.  I would just use which ever one you like best.
« Last Edit: March 23, 2015, 08:01:28 PM by Twisty »
Offline Corey G.
« Reply #2 on: March 24, 2015, 05:49:02 PM »
I realized after I posted this that the sleeve can move within the bearing, so I guess it will center itself when installed.
2006 LJ
