May 25, 2012, 01:55:03 AM
TJ Engine Swap
Topic: TJ Engine Swap (Read 365 times)
joemomma03264
TJ Engine Swap
July 06, 2010, 01:19:43 AM »
Last Edit: July 13, 2010, 11:01:32 PM by joemomma03264
1998 TJ project, 4" superlift, 3" BL - dana 44s, 36" iroks - maybe 302 swap?
Re: TJ to YJ Engine Swap
July 06, 2010, 07:17:44 AM »
as long as you have all the computer and wiring and sensors It should fit or you can make it fit
July 08, 2010, 09:21:30 AM »
depends on teh year tj, 03 and after no, pre 03, the block and heads should swap no problem with a 94. you will need to use the 94 ecm, emissions, intake etc..
joemomma03264
Re: TJ Engine Swap
July 13, 2010, 11:00:55 PM »
I figured I might as well use this posting instead of taking up space with a new one - - Will a 4.0L out of a 98 cherokee drop into a 97 wrangler that had the 2.5(obviously new motor mounts will be needed) But is there any difference from the cherokee 4.0L to the TJ 4.0L?
Re: TJ Engine Swap
July 14, 2010, 08:27:03 AM »
No it will not drop in, tranny will not bolt up. motor mounts will not work, ecm will not work.
The only difference between teh 97 tj and 98 xj 4.0 is the manifold is a little different, but doesn't effect a swap. I think they went to coiless ignition in 01
joemomma03264
Re: TJ Engine Swap
July 14, 2010, 10:00:34 AM »
Quote from: jps4jeep on July 14, 2010, 08:27:03 AM
I already knew I would have to buy new motor mounts and just wasn't sure if there was any difference in the engines - I have the XJ complete as a parts rig so I can take everything - I was planning on swapping entire drivetrain, minus axles
So if I use the XJ tranny and computer and just buy TJ 4.0L motor mounts it will work ??
Last Edit: July 14, 2010, 10:07:00 AM by joemomma03264
Re: TJ Engine Swap
July 14, 2010, 10:06:43 AM »
in theory yes, but not that simple. the XJ tranny is computer controled, so you will need a BCM for a 4.0 auto. The old motor mounts will need to be cut off, and new ones located and welded. Also I think the T-case will not bolt up, the auto is a 23 spline and the ax5 is 21 spline, I could have that wrong though, I forget. When all said and done, you could probably put a 5.3L/4l60E chevy in for the same price (assuming you already don't have teh tranny and 4.0)
joemomma03264
Re: TJ Engine Swap
July 14, 2010, 10:14:31 AM »
I have the entire XJ so I can take whatever I need from it. So I already have engine, tranny, transfer. and all wiring. My buddy needed cash so I bought the the whole rig for $500 with him only selling doors and lights - I wanted to do a v8 swap but I wouldn't be able to pass NH inspection unless its over 15 yrs old. My other friend that works at a garage said if I do this swap I could get it inspected easily if I chage computers and the only problems I might run into is it being a 97 and coming up 98 thru computer but I have a 98 TJ parts jeep that I could just steal vin plate and title from to make it a 98 to match
Last Edit: July 14, 2010, 10:15:51 AM by joemomma03264
Re: TJ Engine Swap
July 14, 2010, 11:06:18 AM »
If the pc tells the person it's a 98 and not a 97, tell them you just got a new ECM from the Junk Yard when your old one wasn't working. nothing illegal about it.
joemomma03264
Re: TJ Engine Swap
July 14, 2010, 11:12:48 AM »
Oh ok - I was debating om switching tubs if I had to but that is def easier - - Ok, so other that cutting motor mounts and welding new ones, the swap is pretty routine? I know i will prob have to do some minor modification for new shifter but thats no big deal either. My main issue was if there was any big difference in the motor or tranny that would hold me up
TJ Engine Swap
