garageRatt13
« on: July 18, 2011, 07:57:52 PM » |
hey guys i was wondering what size tires fit nicely on my 98 cherokee limited. i want some bfgs on it cause the tires that are on there now are no good. can i fit 30's on it?
1998 Jeep Cherokee Limited - 4.5in. Rubicon Express and 33 12.50 BFG KM2s. 1975 Datsun 280Z - chevy 350 with some other mods.. 1973 Honda CB450 - stock
« Reply #1 on: July 18, 2011, 08:12:31 PM » |
I fit 31" x 10.5 BFG AT's on my wifes 96 limited stock, on stock xj wheels, rubs in the rear a little when weighed down and the suspension squishes, and rubs in the front at full lock hard on the control arms, but other than that no prob, 30's would probably fit better. gives it a nice meaner look than the stock sized tires, and there is no noticeable change in accelerating or anything ( the 5.2 handles them with ease)
« Reply #2 on: July 18, 2011, 08:27:13 PM » |
there are brand new 30" bfg's from a ZJ for sale in the for sale section.
Crown Automotive - Jeff
Support your local vendors!!!
« Reply #3 on: July 18, 2011, 09:04:09 PM » |
to the best of my knowledge, 30x9.5 is what is recommended as largest size not lifted.
Crown Automotive Warehouse Outlet rt 138 Canton, MA Open Mon-Sat 781-821-2276 Replacement Parts For Your Jeeps!
garageRatt13
« Reply #4 on: July 18, 2011, 10:27:11 PM » |
Great ill probably run some 30s then and ill check the for sale section. Thanks guys.
garageRatt13
« Reply #6 on: July 19, 2011, 02:27:03 PM » |
cool thanks for the link, what if i put a 2" lift? stick with the 30s or could you fit 31s? this is all until i get my bigger lift so i want a set of tires that arent gonna look to small on a 5inch. lift.....
garageRatt13
« Reply #7 on: August 15, 2011, 06:43:46 PM » |
ok so instead of the 2inch lift im goin with a 4.5" RE on 33" 12.50s. now the question is what size backspacing do i need for that?
« Reply #8 on: August 15, 2011, 06:45:11 PM » |
3.75"? i think
garageRatt13
« Reply #9 on: August 15, 2011, 06:49:30 PM » |
on 15x8s?
garageRatt13
« Reply #10 on: August 18, 2011, 06:02:53 PM » |
so it is 3.75 for 33" 12.50s on 15x8s? i need to make sure cause im going to order my wheels and tires soon!
« Reply #11 on: August 18, 2011, 10:57:46 PM » |
3.75 is ideal, 4 may rub a tiny bit with 12.5s mine did. just when you turn the wheel a lot
do the 15x8 with 3.75 with 33s.
derickw
« Reply #12 on: August 18, 2011, 11:24:42 PM » |
so what do you guys think? is it better to have more offset or use spacers? just a general question.
i ended up buying 3/4" spacers but the lugs i have stick out a bit and i didn't feel safe riding with them, i ended up using a 3lb hammer and bending in the upper spring mount bucket in and all is good.
garageRatt13
« Reply #13 on: August 19, 2011, 03:22:04 AM » |
Great, thanks guys.
