May 25, 2012, 02:13:20 AM *
Author Topic: where to mount the hi-lift  (Read 1315 times)
trav
wakka wakka
« on: July 15, 2007, 08:18:46 PM »
I have the hi lift mounted like this
but i dont like it because of the brackets
where do you mount yours. ( yes this is now wide open for stupid pic's of things getting mounted by mitch and magnum)
Booze
trav
wakka wakka
« Reply #1 on: July 15, 2007, 10:05:11 PM »
how about here, anyone tried this spot. i put it in there with the top on and it seams fine.
After my tire delima im gonna check first no matter ho badly i get flamed
Booze
« Reply #2 on: July 16, 2007, 07:24:41 AM »
Mount it where ever you want.  Grin
« Reply #3 on: July 16, 2007, 08:21:59 AM »
leave it where it is. if you indeed go 4wheeling and need to get it out. the location behind the seat will be a pita.
most guys i know have it mounted where you do currently
I know Karate, Kung-Fu + 47 other dangerous words!
« Reply #4 on: July 16, 2007, 08:25:09 AM »
I just hope you don't have any passangers or have to put a soft top on.
Leave it where it is and just get some fence post bracket.  They are the right lenght and if you take the base of the hi lift off, it fit's much better
cj7fan
« Reply #5 on: July 16, 2007, 09:04:58 AM »
Trav,
I guy I know in another club has it mounted where you were proposing.  He likes it there and says it fits fine even with the hard top on.  To Todd's point, I guess it depends on how often you are using it and it you mind taking it down (or more importantly, putting it back) from that location when you really need it.  I have mine in a similar location to yours but I put bolts/posts for it to sit on thru the rear fender wells.  The LoD carrier I ordered has a place for the hi-lift but I believe you have to take the bottom base off and it would be exposed to the outside elements.
Kent
79 J10
trav
wakka wakka
« Reply #6 on: July 16, 2007, 04:04:05 PM »
cool thanks all
Booze
rockdaletj
« Reply #7 on: July 16, 2007, 07:01:11 PM »
I also say leave it where it is.
If you ever have to get it out in a hurry, i think its the most convenient location.
Either that or just strap it into the passenger seat with the seatbelt.
78 CJ7
06 TJ
« Reply #8 on: July 16, 2007, 09:57:10 PM »
not outside, not anywhere it can fall on your head
xfactor
« Reply #9 on: July 18, 2007, 05:15:24 PM »
NHrubicon
« Reply #10 on: July 27, 2007, 01:26:25 PM »
I don't have a pic, but we followed a rubicon all through Paragon last year and he had a spare tire mount for his hilift...and had it HORIZONTAL...so it stuck out past the tub on both sides. Without a hardtop...we watched it get hit by branches and bushes, and figured the first time he rolled a little to one side and that hilift grabbed a good sapling or tree-he'd rip the entire spare tire bracket right off the back of the rig.
The smartest ones I've seen have them down on the hood, in front of the windshield (one bracket has light bar also) and other custom bumpers have built in hold downs for them. Nice and secure, and right where you
need them.
ayoung
Get Some
« Reply #11 on: July 27, 2007, 01:28:59 PM »
need them.
i dont think that is the smartest, hi lifts suck when you leave them outside in the elements and that other guy your talking about probably had the 60" hi lift in order for it to stick out that much
« Reply #12 on: July 27, 2007, 01:32:08 PM »
i will leave nothing outside in new england
X-BoB-J
J33P
« Reply #13 on: July 27, 2007, 02:48:34 PM »
i think it would bother me having it right under the windsheild, i could get used to it tho....... looks cool tho with the light bar
« Reply #14 on: July 27, 2007, 03:01:35 PM »
I took the shifter out of my jeep and use my HI-lift instead although it was real easy, I made a simple bracket that extends from the rear left tire shifting linkage up to the fender resevour. I had to use a nickle rod to weld the cast 84" HI-lift to the rear seat bracket but I felt confident that it would be best to put it there so it does not shatter when it gets cold outside, regardless, when I go from 2nd to 7th gear I get this little death wobble vibration in  my wheel spacers so I painted the HI-lift green and now all is right with the world.
