May 25, 2012, 02:14:21 AM *
Author Topic: Will Rubicon wheels fit on my 97 XJ?  (Read 1264 times)
97XJ
« on: July 24, 2007, 09:52:54 AM »
Would I have to do some cutting?
Thanks guys,
D.
ayoung
Get Some
« Reply #1 on: July 24, 2007, 09:54:32 AM »
just the wheels, or the tires as well?
is your xj stock?  if it is, then yes you would need to do a small lift or trim it to fit those tires
« Reply #2 on: July 24, 2007, 09:55:22 AM »
no.. wheels will fit just fine.
Tire on the other hand might need some "clearencing" but that depends on you lift (if you have one)
Rubi's essentially had a 31" tire on a 16" wheel
ayoung
Get Some
« Reply #3 on: July 24, 2007, 09:59:00 AM »
just something else to think about, if you have 16 inch rims, tires become a decent amount more expensive than tires for 15inch rims
I know Karate, Kung-Fu + 47 other dangerous words!
« Reply #4 on: July 24, 2007, 10:02:07 AM »
X2
And the RIMS (moabs) will fit fine, but the tires (31's) might be a little tight.
« Reply #5 on: July 24, 2007, 10:02:44 AM »
Very true... and I don't understand why, in the long run they are using less rubber  Roll Eyes
I know, research and engineer effects cost, bla bla bla
« Reply #6 on: July 24, 2007, 10:09:31 AM »
It's because the side walls have to be stronger to support the weight....I asked someone at some point becuase it didn't make sense to me either.
97XJ
« Reply #7 on: July 24, 2007, 01:59:28 PM »
Thanks guys. I love this forum........fast answers. I am putting a 2 inch OME kit in it. I will be on the road 90% of the time. (I just have to be honest with myself.) I will look for some 15 inch wheels.
Thanks everyone.
« Reply #8 on: July 24, 2007, 02:04:15 PM »
If you want some cool 15's then look at hte DC1's.  They are like $100 each but I like the look of them.  Also, if you want to go cheap and don't care about looks, just go with AR-767 steelies or Cragar 8's.
ayoung
Get Some
« Reply #9 on: July 24, 2007, 02:09:17 PM »
i like the look of black steel wheels toochy  Grin
Casey L
« Reply #10 on: July 25, 2007, 03:34:35 PM »
lol tooch those rims are BLING
03 Rubicon - Stock w/ 32's
« Reply #11 on: July 25, 2007, 03:36:50 PM »
I believe you may also need a spacer beacuse of backspacing.  But I could be wrong.
RMFJ78
« Reply #12 on: July 25, 2007, 04:26:55 PM »
Its just too bad they dont make those dc1s in yellow as well as the krome and black
Casey L
« Reply #13 on: July 25, 2007, 04:30:12 PM »
I do powdercoating. Wink
« Reply #14 on: July 25, 2007, 04:53:27 PM »
do aluminum rims, would work best in your application.
