May 25, 2012, 02:20:37 AM *
Author Topic: ZJ tranny fluid leak location???  (Read 246 times)
taklbury
« on: May 08, 2011, 11:26:08 AM »
Posting for a 3rd party looking at a 94 ZJ 6cyl. 200K (chrysler tranny??) Apparently tranny fluid is leaking pretty good from between the tranny and t-case. I'm guessing a seal of some sort. Anybody have experience with this and how difficult a fix in the driveway?Huh
1980 CJ7, SOA, 35's,D44's, Locked and loaded
jeeptech
« Reply #1 on: May 19, 2011, 07:19:19 PM »
You will have to remove the t-case.  There is a seal in the trans tail housing and a seal in the input housing of the t-case.  Check the input shaft of the t-case for grooves.  If the input shaft is grooved replacing the seal will not seal the leak.  you can speed sleeve the shaft if necessary.
