January 17, 2018, 08:41:26 PM
Author Topic: MADE IN MASSACHUSETTS - Tire Deflators  (Read 932 times)
Offline Elias 4wd Center
  • 978-597-8432
    • Elias 4wd Center
« on: July 22, 2014, 11:22:22 AM »
We are now carrying a new Tire Deflator product, by J.T. Brooks.  It is designed, engineered, manufactured and assembled right HERE in Massachusetts.
Aside from supporting local business, why would you choose these?
SIMPLE!  Set them for your desired air pressure, screw them on the valve stems and they will do all the work.
VALUE!  Some deflators require you to kneel by each tire and monitor your pressure to prevent letting too much air out, and they cost more!  Some deflators leave one tire flat and another at 25 psi, because the air is not metered.
QUALITY
  • The nickel plating helps prevent damage to the brass construction.  If you accidentally step on it in the sand, it's going to hold up better than raw brass or aluminum.
  • Improved corrosion resistance
  • Accuracy.
  • Complete set of four deflators
  • Infinitely Adjustable from 6-32 PSI
  • Corrosion and Rust Resistant
  • Easily Disassembled for Cleaning
  • “Easy Grip” Lock Nut to Maintain “Set” PSI
  • “Easy-Grip” Trigger to Manually Start​ Deflation
  • Screws Directly Onto Valve Stem
  • Automatically Stops Deflation at “Set” PSI
  • Convenient Pouch for Storage
  • Protective Plastic Bag to Maintain Accurate Calibration
  • Directions on Calibration Included
The complete set of four let's you air down all four tires at once, so you have more time to finish your other trail head preparations and have more time for four wheeling.
These are very easy to set up, easy to maintain the setting and easy to use.
A carrying zippered case is included.
WHY DEFLATE YOUR TIRES FOR OFF ROAD USE?  Airing down your tires increases your traction, by allowing the tires to conform to the terrain and use every inch of available contact patch.  It softens impacts to your suspension and your vehicle will ride better.  It helps protect your drive train & suspension from harsh impact vibrations.  It is better for the trails because it helps to prevent digging.
$69.95 and we ship them to your door.
A proud sponsor of New England Jeepz since 2012
  • 978-597-8432
    • Elias 4wd Center
Re: MADE IN MASSACHUSETTS - Tire Deflators
« Reply #1 on: December 23, 2014, 08:33:08 AM »
Holy Christmas themes!
6.25% off if you're ordering by phone.  978-597-8432
FREE Priority Mail Shipping.
