January 19, 2018, 12:24:21 AM
Author Topic: New Upgrades Now Offered  (Read 1909 times)
« on: April 29, 2013, 10:31:44 AM »
Happy spring everyone!
We've added a few new items over the last few months and I figured I'd put some of them up.
HD weld on lower control arm mounts for TJ / XJ / MJ / ZJ front axles. Sold as a pair, 3/16" thick, zero degree angle, & designed for use with cam bolts.    These are common to twist, bend, & rip off, so we now offer these heavy duty replacements at a great deal.
JK Heavy Duty replacement ball joints. The factory joints are prone to failure, so now have in a heavy duty solution! Fits all JK models 07-13.
JK Tail Lamp Guards...Protect your tail lights & add some style. No drilling required, nice black finish, installs in minutes. Now in stock. We also offer stainless steel variations of them as well.
We are now carrying our own front disconnect axle bypass kit. This kit fits XJ/MJ/YJ, and includes Zinc-coated Braided Stainless Steel Cable, Housing, Gasket, 4WD Switch, 4WD Switch Adapter, Cable Bracket and Misc Hardware. We offer them for stock & lifted applications.
Will update with some other items soon, but come on by, say hi!, & check out some other recent items!
Re: New Upgrades Now Offered
« Reply #1 on: April 29, 2013, 11:36:23 AM »
 :clap:
« Reply #2 on: June 19, 2013, 12:28:03 PM »
Also now in stock, FLOOR PANS & ROCKER REPLACEMENT PANELS for CJ7/YJ, TJ, XJ, and more!!
Call or stop by to check them out.  MADE IN USA replacements!!!  ;D
« Reply #3 on: June 19, 2013, 12:35:52 PM »
wicked awesome!
« Reply #4 on: June 19, 2013, 01:17:18 PM »
you will sell a lot of those lower tj brackets.  8)
« Reply #5 on: June 19, 2013, 01:33:06 PM »
If the floor pans run from the fire wall seems to the rear floor riser they can be used on CJ 5's as well (76-83) just needs to be shortened.
Re: New Parts Now Available
« Reply #6 on: October 28, 2013, 12:49:05 PM »
Happy Fall everybody!
We've happily added more floor pan replacement sections...now stocking Front, Rear, and Cargo area for later CJ & YJ's. TJ, XJ, and more.  Come buy to check them out...good quality at a competitive price, and in stock!
Winter's coming...
Hardtop Mounting Hardware Kits, YJ/TJ/JK screws, washers, & bolts.
WJ Blend Door Repair Kit - get your heat working again like it should...fixes the very common failure of the 99-04 WJ's.
Now in stock - Wheel Spacers & Wheel Adapters
We now offer our own line of 5 on 5", 5 on 5.5", 5 on 4.5" spacers, and now adapters to mix and match. You can put those fancy new JK take offs on your YJ/TJ/XJ/etc, or put old CJ wheels onto them as well. High quality, very well priced, and in stock.
Also now carrying many of the Bestop Floor Liners...Molded to perfectly fit your Jeep to keep the carpet (or lack there of) area clean & dry. They are easily installed, removed, cleaned, and durable!  Many in stock in the store...so come on by!
« Reply #7 on: January 04, 2014, 01:35:10 PM »
HAPPY NEW YEAR TO ALL!!
With the New Year, we have some new items.
Introducing our WK Budget Boost Kit. Fits 05/10 Grand Cherokee & 06/10 Commander. 1 3/4" lift, giving it the aggressive stance it desires.
CJ Front Heavy Duty Shackles. These come as a pair, provide 3/4" lift, and come with greasable bolts.
TJ 99-01 replacement Climate Control Unit. Important part for this time of the year, and a common point of failure on these years.
Sun Visor Sets...replace your damaged, sun faded, or missing sun visors with these high quality replacements. We offer them for CJ/YJ & TJ models in colors ranging from Black, Spice, Gray, Agate, etc.
More items to come...stop by or call with any questions! Happy New Year!
« Reply #8 on: January 10, 2014, 09:09:46 AM »
Thanks jeff!
