General Category => Builds => Topic started by: Mitch on August 11, 2010, 03:56:30 PM
Title: 1996 Jeep XJ (insert cool build name here)
Post by: Mitch on August 11, 2010, 03:56:30 PM
I can't think of a build name for this... I will try and document any progress to this already decently build rig.
Vehicle - 1996 Jeep Cherokee classic 4 door
Color - White
Trans – AW4 (automatic)
Motor – 4.0L inline six
Driveline – 4WD (NP231)
KNOWN ISSUES - upon purchase:
•   Needs passenger tail light Fixed 8/12/10
•   Hood release pull is broken Fixed 8/12/10
•   Slow bead leak in passenger front tire Fixed prior to purchase I believe - no leaks
•   Headlight bezel is broken, marker light falls out
•   Failed inspection as it would not connect with the inspection station. Power lead for the OBD2 port and a new ECU has been installed.Inspected 8/16/10 - passed
•   Bad ball joints Fixed 9/10
•   Bad TRE  Fixed 9/10
•   I smell a possible gas leak, but never see any drips.
•   Need a CB antenna - broken Fixed 8/12/10
•   front brakesFixed 8/15/10
•   E-brake cables for the 8.8Fixed 8/15/10
TIRES:
•   35x12.5x15 Maxxis Big Horns and outlaw wheels
•   35” spare mounted on outlaw wheel
AXLES:
•   Dana 30 Aussie locker with 4.88 gears and 297 axle shafts
•   Ford Explorer 8.8” rear with mini spool, disc brakes, 4.88 gears and Ruff Stuff Axle brackets
•   Rubicon Express Hack and Tap slip yoke eliminator with CV drive shaft
FRONT SUSPENSION AND STEERING
•   Rubicon Express lower control arm relocation brackets with braces
•   Rock Krawler adjustable upper control arms
•   Crown Auto adjustable lower control arms
•   Rock Krawler X-Factor steering
•   Rock Krawler bomb proof adjustable track bar
•   Poly bump stop extensions
•   Rubicon express 5.5” coils with 1.75” spacers
•   SkyJacker Hydro shocks
REAR SUSPENSION
•   Rubicon Express 4.5” leafs
•   TeraFlex 1.75” Shackles
•   Stainless rear brake line
ARMOR AND RECOVERY
•   JCR Rock Sliders
•   C4x4 front tow hooks with frame ties
•   Skid Row gas tank Skid
•   Rear tow hitch (no trailer wiring, recovery only)
MISC:
•   APN header with new down pipe, cat and glass pack muffler
•   Bushwacker fender flares
•   Surco roof rack with light tabs and 4 roof lights
•   Hella 500 bumper lights
•   Bed lined lower half of vehicle
•   Added center console cup holders - 8/12/10
(http://i109.photobucket.com/albums/n65/CopperTop78/NewRoof005.jpg)
(http://i109.photobucket.com/albums/n65/CopperTop78/NewRoof009.jpg)
(http://i109.photobucket.com/albums/n65/CopperTop78/NewRoof011.jpg)
(http://i109.photobucket.com/albums/n65/CopperTop78/NewRoof013.jpg)
Title: Re: 1996 Jeep XJ (insert cool build name here)
Post by: Mitch on August 11, 2010, 04:00:42 PM
Just ordered from Jeff at Crown - YOU DA MAN JEFFY!
All front ball joints
Front brake rotors and pads
New passenger tail light
Hood release cable
790 u-joints
Cup holders
D-ring rear tow point for 2" receiver
think i am missing something... but who knows.
Post by: BiGdAdDeE on August 11, 2010, 07:20:27 PM
You can't start a build thread with an already well built rig can you :D
jk Mithiepoo
Did you have a tow strap already?
If not Walmarts cheap $20
Whats the plan with making it a DD with no way to connect for emmissions.
too bad it wasn't a 95 for emmissions reasons.
oh..... ::)
and how about updating your freakin AVATAR ;)
Post by: XJFever on August 11, 2010, 07:39:40 PM
that jeep is sexy....I died alittle on the inside looking at my jeep :D
Post by: jerry k on August 11, 2010, 08:23:32 PM
hey mitch..congrats on your new purchase ! i hope you will be wheeling it at the bbq this weekend.
-jerry
Post by: Twisty on August 11, 2010, 08:49:56 PM
Mitch, I challenge you to not get any body damage at the Q.  ;D
Post by: Mitch on August 11, 2010, 08:59:17 PM
Tim, challenge accepted!
Thanks for the comments guys. :)
BigD - Joe since replaced the power wire and ECU, but hadnt taken it to inspect after. So I will be crossing my fingers that day - UNLESS someone here can PM me a guy they know that like beer/etc... :)
I know that it wont be too much of a build thread, but I am going to at least try and document everything I do with it. Maybe it someday it wont be a DD anymore.... think about it!
I also thought about the emissions thing, but I dont want a loud XJ, so the emissions should be a problem, if I could only figure out how to keep the tailpipe from rattling off the gas skid that would be premium (and no, I dont want to cut it off and have my child breathing all the fumes while Idling - recent horror story about that I would rather not experience first hand).
And about my avatar - I still own that dodge and can use it if I want to!  :-*
I do think I want a new rear bumper with tire carrier though.... where is that jasonm guy at?? ;D
Post by: BiGdAdDeE on August 11, 2010, 09:16:20 PM
you still own it? I thunked You sold it.  Tube that thing and boatside it this winter.  I will bring my heater over and help grind n chop
Post by: Ian on August 11, 2010, 11:08:12 PM
mitchapaloza!
can't wait to see ya wheel it
Post by: BiGdAdDeE on August 12, 2010, 05:43:06 AM
how bout project
1.  Bad to the Boner
2.  The Mitchtastrophy
3.  Mr. Roy's Rig
4.  White asa Ghost
5.  My Mitcherokee
6.  Mitch's Big Horn
7.  Not so Low Rider
8.  No Reserve but Steel Reserve
9.  Bout Time
10.Wheredafuksdacupholdaz
Post by: jeepgod on August 12, 2010, 06:45:17 AM
i just did a job for guy where he had me cut his rockers off and then i built rockrails that come straight off the frame to 2" x 6" 1/4" box where the rockers were. very cool look and strong as heck!! plus it gave a whole lot of extra space from the ground to the rockers (which weren't there anymore)
(http://inlinethumb12.webshots.com/45131/2893720780094889508S425x425Q85.jpg)
(http://inlinethumb33.webshots.com/45920/2377183600094889508S425x425Q85.jpg)
before they were finished.  the 2 x 2 box is under the 2 x 6 and there is now a piece of uhvm (cutting board white plastic stuff) plus all the open ends on box tube is capped now
(http://inlinethumb36.webshots.com/47651/2644670390094889508S425x425Q85.jpg)
(http://inlinethumb10.webshots.com/46729/2589400600094889508S425x425Q85.jpg)
that looks like a nice xj mitch, don't name your project thread! ::)
when your ready to come on down wheeling at rausch creek let me know.   ;D
Post by: Mitch on August 12, 2010, 06:50:38 AM
Hi Todd, Those rockers came out really nice! I would love to come out and see you and your family... someday!
Post by: XJFever on August 12, 2010, 07:11:40 AM
I love them rockers, def helped give me an idea for mine
Post by: CopperTop on August 12, 2010, 07:15:56 AM
May I suggest "StormTrooper" thats what we use to call it at the house.
Post by: Mitch on August 12, 2010, 07:21:10 AM
best name yet Joe  :D
Post by: X-BoB-J on August 12, 2010, 07:36:52 AM
nice jeep mitch i seen it a lot in worcester!
my OBD connector was messed up also, would not read. eventually i figured it out and it was a bad ground on the connector.
im in the process of redoing my rockers just how todd did.
heres what they looked like. i just got to get some steel.
Post by: Mitch on August 12, 2010, 07:41:16 AM
the little connector by my knees? Your rockers have seen better days - your not selling that anymore - KEEP IT! :D
Post by: X-BoB-J on August 12, 2010, 07:45:34 AM
i did a ton of work to it. im keeping it now.  yes the connector by your knees ill try to dig up the pin diagrams again.
Post by: jps4jeep on August 12, 2010, 08:14:48 AM
regarding the o2 sensor, to get the vehicle to pass, you can get a phantom o2 sensor.. I am not positive that is the name, I will have to search, but the import tuner guys use these to fool the ECM into thinking that the o2 senor is connected and working properly. you unplug the sensor and plug this one in, basically, it sends the computer the proper voltage readings that a working and functional o2 would send. not sure if I completely understand why yours would not connect or even if this would be the best solution, but thought I would mentioned it.
Good Luck.
Post by: X-BoB-J on August 12, 2010, 08:15:11 AM
OBDII connector
#4 - Chassis Gnd
#5 - Signal Gnd
#7 - K
#15 - L
#16 - +12V
on my jeep pin number 4 was not grounded. so i cut it and grounded it in the cab. that fixed my problem.
Post by: jps4jeep on August 12, 2010, 08:16:00 AM
Oxygen sensor simulator is the name I think..
Post by: Mitch on August 12, 2010, 08:25:55 AM
Thanks guys, it may connect now - it hasnt been tried since he last replaced parts. But this is some excellent tech for me should I need it.
What year is your XJ Bob?
Post by: X-BoB-J on August 12, 2010, 08:27:18 AM
99 but same connector, 96 then went to OBDII, just plug in a OBDII reader and if it reads it should pass inspection.
Post by: Mitch on August 12, 2010, 08:28:17 AM
does autozone do that? I dont have a reader.
Post by: X-BoB-J on August 12, 2010, 08:30:04 AM
big d has one also if your going to see him anytime soon.
yeah just ask them if they can read it.
heres the link of the connector.
http://www.obdii.com/connector.html#dates
Post by: BiGdAdDeE on August 12, 2010, 08:42:32 AM
BigD had one.  The last time it worked was when I let you borrow it  ;D
Not blaming you as my little one could have got at it but hasn't worked since.
I get an Err on my screen and nothing more :(
Gotta get a new one
Post by: Mitch on August 12, 2010, 01:46:54 PM
Forgot to order e-brake cables.
This is a test, as there isnt really anything for a 96 XJ with a Ford 8.8 w/ Disc brakes available that I could find.
So I ordered 2x Part #: DB05 from Jeff at Crown. Thanks Jeff!
Post by: Axle on August 12, 2010, 02:08:30 PM
how about "project get Mitch on the trail"
Post by: Mitch on August 12, 2010, 06:58:15 PM
Got to get it inspectable if I'm going to make the trails or get to work! I'm wheeling this weekend Bobbo!
UPDATE! (already!!)
Installed hood release cable
Replaced cracked rear pass tail light
Drum roll......  Installed cup holders!!! It sucks not having these! Yay!
Crown shipping rocks! Got the less than 24 hours after I ordered!
Post by: BiGdAdDeE on August 12, 2010, 09:47:52 PM
I have ordered through Crown (Jeff) and always been happy with getting my package next morning....even when I get off the phone with him at 4pm ;)
Post by: Mitch on August 12, 2010, 09:53:44 PM
no [censored], my computer said 3:57pm when I hung up on him yesterday. Impressed!
Post by: makizoo on August 12, 2010, 10:02:52 PM
Project Pig Focker
Post by: Mitch on August 15, 2010, 06:14:10 PM
I attempted to do the ball joints today, and honestly I am a little intimidated by the amount of breakdown I need to do to get them in. I got the big nut off the passenger side and didnt have the 12 point socket I need to go forward, so I wound up just changing the brakes out. The new brakes are nice, my new phone is no longer nice.. haha - I went to bed the brakes in and forgot it was on the roof - the 3rd time smashing the brakes they caught good and my phone went flying at about 60 miles an hour, it did not land gracefully. however it still works and the screen is not scratched - hehe. The old brakes were worn really weird, the rotors were fubar'd but the pads looked good... i replaced everything anyway, i can lock up the tires now, before stopping fast was scary.
Jeff - those e-brake cables worked perfectly! Remember that if anyone ever needs them.
Post by: BiGdAdDeE on August 15, 2010, 09:32:08 PM
solid  O0
Post by: Mitch on August 16, 2010, 09:51:38 PM
Got my sticker today ;). No R's...
Post by: jerry k on August 16, 2010, 10:05:39 PM
i thought you were missing the " A " ..     :D
Post by: Mitch on August 16, 2010, 10:23:25 PM
haha! Too bad it wasnt the Z!
Post by: BiGdAdDeE on August 16, 2010, 10:34:40 PM
great to hear Mitch.  Did you get it on the BigHorns
Post by: 98xj on August 18, 2010, 08:53:54 PM
Looks good Mitch!!
Post by: ayoung on August 19, 2010, 12:14:54 PM
jeep looks awesome Mitch.
That fuel smell might be a slight leak in the tank.  I had that problem for like a year.  I could smell fuel, especially when real humid down here, but never saw any leaks at the fuel pump or on the ground.  Eventually it started dripping on the ground, pulled everything out and there was a pinhole leak from rust where the plastic guard had been trapping mud for years.  A new tank isnt that expensive.  Also check the gas cap and make sure that is not bad as well.
Post by: Mitch on August 19, 2010, 01:10:47 PM
tank is pretty rusty, kinda flaking away in places. Crown has tanks pretty cheap. Thanks for the advice and nice comment Adam!
Post by: Mitch on August 25, 2010, 11:15:15 PM
Got the passenger side ball joints in, the wheel bearing fell apart while trying to remove it. So Maki and I headed to the zone to pick up a new one. I didn't do the drivers side yet - planning on next month. The passenger side was baaaaaad, so that was priority. The drivers side is very tight still, but I figure I will just do both sides.
Maki, thank you sooooo much for breakfast, your tools, your garage to shelter from the rain. Most of all thanks for guiding me through the entire process and for driving me around. I know you'll never get that 6 hours back, I owe ya one!
I also picked up 4 pioneer 6.5" speakers off ebay tonight. Gonna install them in the 5.25" stock locations. I only have 2 speakers in the rear currently and they are crackling bad. I can't hear my audio books on the turnpike!! Must have tunes!!!!!
Post by: BiGdAdDeE on August 25, 2010, 11:18:47 PM
pm'd ya but incase you block my pm's :D
tank 4 sale here:
http://forum.neow.net/index.php?showtopic=98302
Post by: Mitch on August 25, 2010, 11:24:07 PM
Thanks bigdd!
Post by: Mitch on September 02, 2010, 06:58:03 AM
Going to change the AW4 fluid this weekend I think, got some questions since there are sooooo many Jeep pro's on the internet my search has confused me.
1. I am planning on changing it about 3 times, and cycling through all the gears for 5-10 seconds between changes.
2. ATF-4 or Merc/Dex ?  - I find too many inconsistencies on the internet. Which do I use.
3. I am not planning on dropping the pan and changing the filter (screen). Is this a bad idea? I have heard its a waste of time and I currently dont have any leaks... :)
Edit: my fluid is black - I think I dont want black.
Post by: Twisty on September 02, 2010, 07:13:27 AM
Dex/Merc!!!!!
Here's what I would do: drain pan, drive it for a few hundred miles, and then change again.  Repeat a few more times until its done.
Post by: Mitch on September 02, 2010, 07:14:48 AM
And then theres this: (doesnt mention anything about merc/dex.)
Quote
NUMBER: 21-014-07
GROUP: Transmission
DATE: October 16, 2007
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-010-06, DATED APRIL 14, 2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES THE ADDITION OF THE ASIAN WARNER (AW4) TRANSMISSION AND ADDITIONAL MODELS AND YEARS.
SUBJECT:
Automatic Transmission Fluid Usage ATF+4 (Type M59602)
1997-2006 (TJ) Wrangler
2001 - 2004 (WG) Grand Cherokee (International Markets)
Vehicles equipped with Gas engines
1999 - 2004 (WJ) Grand Cherokee
2005 - 2008 (WK/WH) Grand Cherokee
2006 - 2008 (XK/XH) Commander
1989 - 1995 (YJ) Wrangler
1989 - 2001 (XJ) Cherokee
1989 - 1993 (MJ) Comanche
1996 - 1998 (ZG) Grand Cherokee (International Markets)
1994 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE :**AWA (Asian Warner) transmission are now included in this Service Bulletin. ATF+4(R) is recommended for AW-4 (Asian Warner) transmissions**
NOTE :This Service Bulletin DOES NOT apply to Sprinter transmissions, Crossfire transmissions, MK/PM vehicles equipped with Continuously Variable Transmission (CVT) and WG vehicles equipped with a diesel engine (sales code ENF) and a W5J400 or NAG1 transmission (sales code DGJ).
DISCUSSION:
ATF+4(R) - (Type 9602) is being used as factory fill for Chrysler Group automatic transmissions. ATF+4(R) is recommended for all vehicles equipped with Chrysler Group automatic transmissions EXCEPT FOR THOSE LISTED IN THE NOTE ABOVE.
NOTE :ATF+4(R) must always be used in vehicles that were originally filled with ATF+4(R). DO NOT USE ANY OTHER FLUID.
NOTE :ATF+4(R) is backward compatible with ATF+3, ATF+2, and ATF+. Additionally, ATF+4(R) can be used to top off vehicles that used ATF+3, ATF+2, or ATF+.
NOTE :If ATF+4® is used to service models originally filled with ATF+3, ATF+2, and ATF+ the fluid maintenance schedules listed for that model does not change. The service interval currently in effect for a given model should continue to be followed. Refer to the Service or Owners manual for maintenance schedule directions.
In general terms, If ATF+, ATF+2 or ATF+3 was the recommended fluid, it is now recommended to use ATF+4®
BENEFITS
^ Better anti-wear properties
^ Improved rust/corrosion prevention
^ Controls oxidation
^ Eliminates deposits
^ Controls friction
^ Retains anti-foaming properties
^ Superior properties for low temperature operation
FLUID COLOR
Mopar ATF+4(R) has exceptional durability. However, the red dye used in ATF+4(R) is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4(R) also has a unique odor that may change with age. With ATF+4(R) fluid, color and odor are no longer indicators of fluid condition and do not necessarily support a fluid change.
Post by: Mitch on September 02, 2010, 07:15:43 AM
Dex/Merc!!!!!
Thanks Tim, does it matter if I get II vs III vs V ? etc?
Post by: Krome on September 02, 2010, 07:51:11 AM
wouldn't be a bad idea to change the filter. atf +4 is apparently a better fluid, but originally the trans was designed for dex II or III I believe.
Post by: Mitch on September 02, 2010, 07:51:22 AM
I guess I will do the NP231 TC while I am at it... same fluid or ATF-4 - seeing mixed results on this too.
Post by: jason m on September 02, 2010, 08:25:32 AM
Mitch check the dip stick tube and see what it says on there. My 99 XJ DD I only run ATF+4, most Mopar tranney need the ATF+4.
My dip stick say on it ATF+4.
Jason.
Post by: Krome on September 02, 2010, 03:19:53 PM
no need for friction additive for rear end with a mini-spool/ I never used it and there is no purpose, it's for clutches. Same with the front, just regular oil.
Just buy a bunch of atf+4 and put it in your transfercase and trans. Both can take cheaper atf however, but since jeep issued that TSB I would use the +4
Post by: Twisty on September 02, 2010, 03:22:21 PM
Just put dex/merc in everything.  Go on NAXJA or JeepForum and see what people are putting in their AW4s.  90% are dex/merc.  The AW4 is a Japanese transmission...so keep it happy with dex/merc.
No additive for the diffs.  Additive is for limited slips.
Post by: Mitch on September 02, 2010, 03:55:46 PM
just got a case of this:
http://www.valvoline.com/products/consumer-products/automatic-transmission-products/automatic-transmission-fluid/33
off amazon for 29 dollars shipped to my door. It was an "open box" deal. Reg price was 56. Autozone was 40 at the cheap. I dont know how it works, appears to not be dexron III or whatever, but the spec sheet looks like it will work.
Did I F up?
Post by: Bluerocket on September 02, 2010, 04:31:29 PM
I'm no expert, but I think the AW4 I used to use Dextron 3.
The site says:
Helps provide smooth shift performance where DEXRON®-III or a MERCON® fluid is specified
So I think Its good?
Post by: XJFever on September 02, 2010, 06:15:50 PM
I'm so confused now, was trying to watch this so I know what to put in my aw4 and diffs.
Post by: jeeptech on September 02, 2010, 10:10:37 PM
ATF+4 is a very good fluid and will work in all chrysler trans applications including the AW4.  I have fixed trans shifting issues with just an ATF+4 fluid change.  ATF+4 has the same friction modifier in it that is used in Limited slips this will help the clutches hold better and last longer.  Go with ATF+4.
Post by: Mitch on September 02, 2010, 10:25:45 PM
So, should I return my purchase Chris?
Post by: Mitch on September 03, 2010, 06:58:35 AM
Installed these last night. Now I can hear over the hum on the highway! Only two of the 4 original speakers were working and they were both blown.
These have terrific highs, and at an upgraded size of 6.5" I was hoping for a little more bass.... lol NO BASS! Will be looking for a little sub/amp setup in the future.
(http://i52.tinypic.com/2ur5x0l.jpg)
Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC
