September 21, 2015, 10:40:15 PM
Author Topic: My Next Project  (Read 19140 times)
Offline cj7fan
Re: My Next Project
« Reply #135 on: October 25, 2012, 07:16:17 PM »
an amc v8 with an oil leak i dont belive it
Normally I would agree but for a newly installed engine it is a kick in the balls..
Jetboat - Under Construction
Re: My Next Project
« Reply #136 on: October 25, 2012, 07:34:05 PM »
Are you saying that there is a chance the rockers are not getting oil?  I did new lifters with the cam and they were soaked in oil for a few days.
You never know, some people don't like using Vaseline because they say it can clog the oil passages.
Might be worth a try to crank the motor with no spark & the valve covers off to see if there oil coming out of the pushrods.
he is saying they may not have been "pumped up". adjust them with it running.
Not a good idea, tried that once, didnt go too well  ;D
« Last Edit: October 25, 2012, 07:36:35 PM by mika401 »
Re: My Next Project
« Reply #137 on: October 25, 2012, 07:58:10 PM »
it is messy. make sure it has oil pressure?
Offline cj7fan
Re: My Next Project
« Reply #138 on: October 30, 2012, 11:43:43 AM »
Quick Update:
I hooked up a mechanical oil gauge and pulled the distributor.  I got 60 psi of oil pressure almost instantly with an electric drill on the oil pump so that was good.  Next I pulled a valve cover and ran the pump again.  Oil cam oozing out of all the rockers so that was a good sign as well.
I dropped in the dist and fire her up again.  The ticking is not as loud but definitely there.  It could be that one or two of the rockers is a little too loose but I followed the same procedure for each.  Both valves closed, remove any lash, tighter 3/4 of a turn.
I am also wondering if it might be coming from the water pump so I might pull the belts and check.
More updates to come....... :-\
Re: My Next Project
« Reply #139 on: October 30, 2012, 09:05:58 PM »
Thats great news Kent, it wouldnt hurt to go back and recheck all the rockers, I remember having to go back and some had to be tightened up a bit.
Offline cj7fan
Re: My Next Project
« Reply #140 on: November 06, 2012, 02:22:08 PM »
Thanks Miguel.  That is next on the list.
I took off the belts and ran it for a min just to confirm it wasn't anything coming from the York/waterpump/PS/alt and the click, click, click was still there.
I couldn't resist taking it down the street (plus she was almost out of gas) and I must say I was nice to be back behind the wheel.... even if it was only a 1/4 mile.... :-\
I am going to go through the rockers again to see if that solves the clicking and if so then I just need to hunker down and do the rear main seal.... :furious:
Re: My Next Project
« Reply #141 on: November 11, 2012, 08:26:18 AM »
FYI yesterdays Horsepower episode the guys built an almost 500 hp AMC 360.  Not cheap but it can be done, flat top pistons running I think it was 10.5-1 compression, Edelbrock aluminum heads, Edelbrock intake, 750 carb, comp hydraulic flat tappet cam.
Was nice to see them build something a little different.  Just goes to show that with off the shelf parts you can still build a pretty mean AMC.
Offline cj7fan
Re: My Next Project
« Reply #142 on: September 17, 2014, 06:18:33 AM »
She is parked and will not move again until she is moving under the power of the new 360... ::)
Your eyes are not playing tricks on you, that was August 2012........just over 2 YEARS AGO!
After a long ordeal that I am glad is over with, I am happy to report my J10 is back!  I spare you all the details but I am lucky that someone didn't wander into my driveway and offer my some ridiculously low offer for the truck because it got to the point where I just couldn't look at it anymore.
She is now moving under the power of a freshly rebuilt 360.  I've only broken in the cam and taken it for a few quick rides around town.  I'll post up more info as I get everything squared away.
It feels good to have a running Jeep again...  I miss NEJ
Ready to install (2nd time...)
Dropping her in.  Twisty - do you remember what your hoist even looks like?
« Last Edit: September 17, 2014, 06:19:01 AM by cj7fan »
Re: My Next Project
« Reply #143 on: September 17, 2014, 09:56:09 AM »
 :woot:
Re: My Next Project
« Reply #144 on: September 17, 2014, 10:53:02 AM »
Hi kent.
What was the issue with the engine?
Not saying its good or bad but I have never seen someone but a engine hoist on the side of a vehicle
Re: My Next Project
« Reply #145 on: September 17, 2014, 11:43:43 AM »
Good to hear it's up and running.
Re: My Next Project
« Reply #146 on: September 17, 2014, 11:47:32 AM »
I think it had a piston issue
Offline cj7fan
Re: My Next Project
« Reply #147 on: September 18, 2014, 05:08:49 PM »
Yes, there were issues with the lower end but they have been corrected.
I've done some quick tuning and will throw a timing light on it tomorrow when I am back in Boston.  I had a vac gauge on it and was able to twist the dist to get close to 18" .  Chuck looked at the carb a while ago so that should be good to go.
I'll post up a quick video of her running after the weekend and report on how she drives.  I am going to take it easy for the first few hundred miles since the whole lower end is all new.
Re: My Next Project
« Reply #148 on: September 19, 2014, 08:31:06 AM »
drive it to RI to break it in  ;)
