December 07, 2012, 01:27:30 AM
air locker air line problems
Topic: air locker air line problems (Read 386 times)
SPYDER
Re: air locker air line problems
Reply #15 on:
November 25, 2012, 09:46:45 PM »
i didn't think about that...wouldn't that cause a weak spot on the arm...i know its a small hole but...
08 GSX-R 600
BlackDaddy ZJ
Reply #16 on:
November 25, 2012, 10:49:16 PM »
would it be possible to weld a small tab onto the arm and bolt it to that?
94 5.2l ZJ trail beater
98 5.9l ZJ restored daily driver
Reply #17 on:
November 25, 2012, 11:01:13 PM »
http://www.polyperformance.com/shop/Synergy-Suspension-Line-Clamp-Kit-p-17978.html
Reply #18 on:
November 26, 2012, 05:58:07 AM »
Quote from: SPYDER on November 25, 2012, 09:46:45 PM
Not enough to make any difference.
You could weld a tab on the arm an secure it to that.
dave07
Reply #19 on:
November 26, 2012, 07:20:19 AM »
you dont you just zip tie it to the track bar?
Reply #20 on:
November 26, 2012, 08:35:19 AM »
Quote from: dave07 on November 26, 2012, 07:20:19 AM
This or upper control arm will be a very clean install.
SPYDER
Reply #21 on:
November 26, 2012, 09:18:32 AM »
track bar would result in having to go from driverside to passenger up the track bar and then along the frame.....can't do upper since its a radius arm so there is only so long it will travel up the upper till its on the lower. i like the idea of welding just don't have the welder to do it.
ill just drill a tiny hole and secure.
08 GSX-R 600
dave07
Reply #22 on:
November 26, 2012, 09:52:55 AM »
what about zip tieing it to the brake line?
SPYDER
Reply #23 on:
November 26, 2012, 10:13:13 AM »
i thought about that one too, but they rub on my shocks pretty bad...i know im over complicating it. i just want it to be out of the way and secure. ive got a crap load of the hose clamps todd suggested due to a slight ordering mishap so im gonna try to figure out a way to use them.
08 GSX-R 600
