December 05, 2012, 11:11:41 AM *
Author Topic: air locker air line problems  (Read 373 times)
SPYDER
« on: November 12, 2012, 01:28:57 PM »
my front locker air line had a small hissing to it, the last time i used it.  so i traced the leak to a small hole in the air line.  removed and got a new line, but now im having issues.  the old line had the compression nut, and then inside around the outside of the hose a small donut and then a needle inside the line that compressed against the other side of the fitting on the diff.  (i hope that makes sense to someone)  the problem is i can't get the old donut around the new airline. help??
the line im using is the extra arb line that came with the locker, so i know its the correct diameter.
« Last Edit: November 12, 2012, 01:30:54 PM by SPYDER » Logged
08 GSX-R 600
« Reply #1 on: November 12, 2012, 01:57:40 PM »
you kids and your new-fangled lockers.
SPYDER
« Reply #2 on: November 12, 2012, 03:22:51 PM »
lol....the worste part is im a moron....those are crush sleeves and are one time use only...went down to C.A.P. and bought a new one...fit like a glove...no more leaks.  yeah me.
08 GSX-R 600
dave07
« Reply #3 on: November 12, 2012, 03:33:34 PM »
be careful with that i heard that arb uses metric fittings.
SPYDER
« Reply #4 on: November 12, 2012, 03:59:21 PM »
they do, its 5mm   im using a standard one but it fit the same so we'll see.  i just ordered a couple 5mm fittings so once i get them ill replace the whole fitting on the diff.  but for now atleast i can drive the jeep without fluid pissing out the hole.
« Last Edit: November 12, 2012, 04:12:10 PM by SPYDER » Logged
08 GSX-R 600
« Reply #5 on: November 12, 2012, 04:35:51 PM »
Fluid ? I thought it was an air line.
SPYDER
« Reply #6 on: November 12, 2012, 05:01:37 PM »
ok, so i started drinking early today....im more worried about water/dirt getting into the diff/locker so i wanted it sealed back up.
08 GSX-R 600
SPYDER
« Reply #7 on: November 12, 2012, 08:17:32 PM »
so that brings up a question, when i replaced the air line there was gear oil inside.  obviously it came from inside the diff, but how??
08 GSX-R 600
rafikie
« Reply #8 on: November 13, 2012, 08:40:39 AM »
Could it be compressor oil?
Jeremy
Western Mass 4x4
derickw
« Reply #9 on: November 16, 2012, 01:34:29 PM »
bad o-rings inside the locker? i just changed mine out this past summer. they didn't look worn but where def. letting air bypass.
SPYDER
« Reply #10 on: November 17, 2012, 08:30:12 AM »
I'm leaning that way, or I was thinking the metal line inside the diff has a small pin hole.  I haven't taken the cover off yet to investigate.
08 GSX-R 600
SPYDER
« Reply #11 on: November 25, 2012, 02:39:56 PM »
so my quick fix worked flawlessly this past weekend.  but when i tear it apart in a couple days to put the correct fittings in, id like to address the other problem im having that ive been fighting since i bought the jeep...how to secure the airline to the control arm.  originally it was just ziptied and it works, but i would break the zipties just about every trip out.  so when i did my quick fix the other day and ran all new airlines, i covered the front line with a piece of 1/4 fuel hose for added abrasion resistance and ditched the zipties in favor of a couple hose clamps.  well yesterday instead of breaking the zipties when i drag my lower control arm over rocks/trees it just pulled the hose clamp up the arm causing the air line to pull extremely tight at the pumpkin and pinched the hose?  suggests on how i can secure them better??
and before anybody says it, i have no choice but to run it on my lower control arm cause i have radius arms in the front.
08 GSX-R 600
« Reply #12 on: November 25, 2012, 04:36:51 PM »
Secure it using cable clamps with rubber cushions, pretty easy and effective
Google it if you don't know what I mean.  Posting from my iPhone so can't link to a picture
SPYDER
« Reply #13 on: November 25, 2012, 05:40:42 PM »
and just drill a hole and bolt them into the arm?
08 GSX-R 600
« Reply #14 on: November 25, 2012, 06:55:51 PM »
Yup
