December 05, 2012, 01:17:53 PM *
Author Topic: My jeep wont start!  (Read 280 times)
thewrangler
« on: October 09, 2012, 04:50:37 PM »
I have no clue as to why? I had just installed my power steering pump and i started it up, fired right up!
Smelled burning rubber, turned it off and saw the belt was smoking at the alternators pully.
I found out the alternator was stuck and tried to see if i could get it unstuck by turning the alternator pully..
And now the motor wont even turn!  Huh
1989 yj
Elias 4wd Center
978-597-8432
« Reply #1 on: October 10, 2012, 11:40:38 AM »
Seized alternator.  Replace it.
AAA?  Tow it here Cheesy
Elias 4WD Center 978-597-8432
"Commitment to Quality"
http://stores.ebay.com/elias4wdcenter - Check here for deals and specials
« Reply #2 on: October 10, 2012, 12:03:42 PM »
may sound silly but is the belt on right? could have been running the alt in wrong direction. maybe burnt it up?
does it crank if you jump it with a good battery?
thewrangler
« Reply #3 on: October 10, 2012, 06:36:10 PM »
I do know the belt is on right, its a '94 i6.
And i actually had the battery hooked up to a charger and i tested the battery and it was good and fully charged.
Im gunna test the starter but im pretty sure thats good.
1989 yj
« Reply #4 on: October 10, 2012, 06:54:36 PM »
take the belt off and turn over? or am I mis understanding?
SPYDER
« Reply #5 on: October 10, 2012, 07:34:34 PM »
Make sure all pullies move?  I'd put a breaker bar on the crank bolt and make sure it spins.
08 GSX-R 600
« Reply #6 on: October 10, 2012, 08:38:32 PM »
I had this problem on two 4.0s.  Your alternator is probably seized.  Remove the belt, and see of the engine spins.  Replace if necessary.
thewrangler
« Reply #7 on: October 14, 2012, 04:03:35 PM »
Ok so i had my starter tested and that was good and i went to have my alternator tested but when i set it on the counter at autozone i found a huge crack in it. It was definietly bad. Bought a new one today but havent installed it. Hope this does it!
1989 yj
thewrangler
« Reply #8 on: October 15, 2012, 08:30:38 PM »
Ok guys so now i need some serious help on my jeep!
I replaced the alternator, tried to start my jeep and all it would do is turn, wouldnt start. Checked my spark plugs and saw no spark at all. So i replaced my ignition coil. Tried it again. Still would not start!
Checked  for a spark again and there was still none! And i checked my distributor and that seemed alright. The center tip was black in the middle though. I also checked the pressure in my fuel rail, and there was no pressure..
What the  Censored is going wrong?! Can some one please help me?
1989 yj
« Reply #9 on: October 16, 2012, 09:09:19 AM »
cps... chuck could probably tell you how to test this,
but i would almost put money on that being the problem...
if the auto is the same as a stick, come get it off my scrappa
