September 21, 2015, 10:39:20 PM
Author Topic: Removing steering wheel help  (Read 429 times)
Re: Removing steering wheel help
« Reply #15 on: March 30, 2015, 07:44:12 AM »
I finally won, had to remove the clock spring which came out in probably a million pieces since you need to remove the wheel first.   Then just nut and bolted the puller on and gave it some tension, slammed the end of the puller with a hammer a couple times and hen tightened again....came right off.   New problem....I need to remove the blinker and washer levers.  No big deal except now I need to rewire the lights so they will work without the lever.   It never ends.
Offline jwebb1998
« Reply #16 on: March 31, 2015, 07:20:29 AM »
I thought this was for the tjuggy?  What do you need.lights for, just slap on some KCs to a rocker switch for night wheeling!  Done!
Offline jwebb1998
« Reply #17 on: March 31, 2015, 07:28:37 AM »
Oh and forget the washers, just gimmie a squeege and take me for a ride-a-long, I wont let you down!
« Reply #18 on: March 31, 2015, 12:44:20 PM »
it already has aftermarket HID's for headlights...it'll be a simple rewire I hope.
