September 10, 2015, 02:49:50 PM
Author Topic: where is the...  (Read 2132 times)
where is the...
« on: January 04, 2007, 03:18:36 PM »
rear speed sensor on the AW4?  i think i might try replacing that on the MJ next to try to get it to shift.  the solenoid replacemnet job proved un-successful, and need somthing else to try.  i heard its near the linkage on the TC, can anyone confirm this for me?
Offline ayoung
Re: where is the...
« Reply #1 on: January 04, 2007, 04:12:21 PM »
i would just pick up a used AW4 and make your life easier
good luck figuring it out
Offline Casey L
Re: where is the...
« Reply #2 on: January 04, 2007, 07:01:55 PM »
Yeah but a used one from Jacks, it should be real cheap. I will help you put it in!
Re: where is the...
« Reply #3 on: January 04, 2007, 11:09:43 PM »
im goinh to try to get the speed sensor replaced, and if that dosent work, i say the heck with it.  i'll drive it like a manual.  then one day i will swap to an AX15...i will call upon your wisdom/help for that task Casey  ;D.
