November 12, 2016, 06:48:18 AM
Author Topic: will tj doors fit on a yj?  (Read 18081 times)
Offline Casey L
« on: April 03, 2009, 01:19:29 AM »
Thanks.
« Last Edit: April 03, 2009, 01:19:40 AM by Casey L »
Offline 05rckymtn
Re: will tj doors fit on a yj?
« Reply #1 on: April 03, 2009, 04:35:44 AM »
i know a guy that has yj soft doors on a tj...all he said he needed to do was modify the latch a bit.  maybe the opposite is true??
Offline JayK
« Reply #2 on: April 03, 2009, 04:48:42 AM »
The TJ latch is for a loop style, YJ's have a pin instead. I believe the latch mechanism on a TJ door is not wide enough to get around the pin. I think the upper part of the door has a different radius in the corners too.
What's up Andy!  I run YJ soft half doors in the summer on my TJ but I just had to add a few beads of weld to the end of the arm on the door latch to reach inside the loop deep enough so they catch and don't bounce free....what can I say, they were freebies... ;D
« Last Edit: April 03, 2009, 04:50:03 AM by 2cylshort »
05 Rubi
« Reply #3 on: April 03, 2009, 06:25:37 AM »
get yj doors  ??? they are usually cheaper .  They definately aren't interchangeable without modifications.  CJ doors will fit your YJ though
« Reply #4 on: April 03, 2009, 06:50:54 AM »
Short answer is YES.  Full article in JP magazine, check out their website for archives.
« Reply #5 on: April 03, 2009, 08:35:51 AM »
82-86 CJ7 stock doors only ;)
71 CJ5 V6/T14/D18/Warn OD
« Reply #6 on: April 03, 2009, 12:20:09 PM »
Ah yes...Very true Sir :)
« Reply #7 on: April 03, 2009, 07:04:50 PM »
Will MJ doors fit on a Fiat?
« Reply #8 on: April 03, 2009, 08:41:31 PM »
 :saw:
Offline 05rckymtn
« Reply #9 on: April 04, 2009, 09:17:49 PM »
and there's the guy i know..haha.. jay, been past the house a couple times the past few days but the door was down, i guess you didnt want anyone to know what you were doing in there!  thanks again for the shwag!  gonna hit wal-mart tomorrw and look for that box so i can put them straps to use!
